Making a modbus formatted packet
Neutone
PostPosted: Thu Mar 13, 2003 4:29 pm     Reply with quote
This is a way to create a modbus formatted packet of a fixed length. This function is formatted to send 4 bytes to a memmory address. This is a good way to monitor process variables over a serial port and it uses CRC16 error checking. I pickup good ideas in this forum all the time. It just feels like time to contribute something of substance.
int8 PacketBuffer[10],x,z;
int1 FlagXOR;
PacketBuffer[0] = slave_address;
PacketBuffer[1] = Function_code;
PacketBuffer[2] = Address_lo;
PacketBuffer[3] = Address_hi;
PacketBuffer[4] = data0;
PacketBuffer[5] = data1;
PacketBuffer[6] = data2;
PacketBuffer[7] = data3;
PacketBuffer[8] = 0xff; // Prepair CRC
PacketBuffer[9] = 0xff; // Prepair CRC
for ( x=0; x < 8; x++ )
{ z = PacketBuffer[x];
PacketBuffer[8] ^= z;
for ( y = 8; y > 0; y-- )
{ FlagXOR = bit_test( PacketBuffer[8], 0 );
shift_right( &PacketBuffer[8], 2, 0 );
if ( FlagXOR )
{ PacketBuffer[8]^=0x01;
PacketBuffer[9]^=0xA0;
___________________________
Original Post ID: 12642
Hans Wedemeyer
Re: Modbus simulator available
PostPosted: Thu Mar 13, 2003 6:09 pm     Reply with quote
I found several simulators that generate/simulate a response as if it were a slave, but never found a master simulator.
If anyone needs an small windows app to generate modbus messages and test them via RS-232.
The program allows the user to select
SLAVE ID
MESSAGE ID
enter ASCII text
Generates check sum and send the message then wait for a response.
It will find and use any RS-232 on a Windows 2000 system, should also work on XP and NT
Program captures response from slave and displays it in Plain ASCII or Hex.
Original Post ID: 12647
PostPosted: Fri Jun 03, 2005 12:05 pm     Reply with quote
GOTO www.win-tech.com and they have demos for modbus master/slave testing and development.
