how to set 12f675 MCLR pin?
young
PostPosted: Thu Jun 02, 2005 11:14 am     Reply with quote
I want to use the PIN_A3 as a reset pin (12f675), so that when I trigger this pin, the chip will reset and start again, How can I do it< I did not find the related command in ccs c. thank you
PostPosted: Thu Jun 02, 2005 11:35 am     Reply with quote
This question was answered on May 15th.
Somehow I suspect that you are all in the same class at school.
http://www.ccsinfo.com/forum/viewtopic.php?t=23008&highlight=mclr+nomclr
young
PostPosted: Thu Jun 02, 2005 12:04 pm     Reply with quote
I used MCLR for the other chips, it works fine, when I used for the 12f675, my other function like external interrupt stop working, any possible reasons?
PostPosted: Thu Jun 02, 2005 12:28 pm     Reply with quote
Post a small complete program that shows the problem.
Be sure to post the #fuses statement, #use statements, etc.
Also post your version of the CCS compiler.
young
PostPosted: Thu Jun 02, 2005 12:40 pm     Reply with quote
thank you, here is the whole program:
#if defined(__PCM__)
#include <12f675.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,MCLR
#use rs232(baud=9600, parity=N, xmit=PIN_A0,INVERT)
void LCDSetGeometry();
void LCDReset();
void LCDinit();
void LCDSetBackLight(int8 backlit);
void LCDSetContrast(int8 contr);
void LCDClrScr();
void LCDNewLine();
void LCDCR();
void LCDTab();
void LCDVerTab();
void LCDBackSpaces(int8 bspa);
void LCDSetTab(int8 Stab);
void LCDSetCursorPos(int8 x, int8 y);
void LCDClrLine(int8 x, int8 y);
void LCDSetCursorStyle();
void LCDOnOff(int8 onoff);
int16 count;
#INT_ext
void ext_isr()
count++;
  setup_adc_ports (NO_ANALOGS);
  setup_comparator(NC_NC_NC_NC);  //setup_comparators(NC_NC_NC_NC); no "s"
  LCDinit();
  LCDClrScr();
  LCDSetCursorPos(0,0);
  puts("*Pulse counting*");
  count=0;
  EXT_INT_EDGE(L_TO_H);
  enable_interrupts(INT_ext);
  if(input(PIN_A1))
    count=0;
  LCDSetCursorPos(1,1);
  printf("Num=%lu   ",count);
   putc(15);
   delay_ms(10);
   putc(16);
      delay_ms(10);
   putc(0x80);
      delay_ms(10);
   putc(0xc0);
      delay_ms(10);
   putc(0x80);
      delay_ms(10);
   putc(0x80);
      delay_ms(10);
void LCDReset()
   putc(14);
void LCDinit()
   // Set LCD Geometry
   LCDSetGeometry();
   // LCDReset
   LCDReset();
   putc(20);
   delay_ms(10);
   putc(backlit);
   putc(19);
   delay_ms(10);
   putc(contr);
void LCDClrScr()
   putc(12);
   delay_ms(10);
void LCDNewLine()
   putc(10);
   delay_ms(10);
void LCDCR()
   putc(10);
void LCDTab()
   putc(9);
void LCDVerTab()
   putc(11);
   int8 i;
   for(i=1;i<bspa;i++)
      putc(8);
   stab=(stab^0xFF)+1;
   putc(16);
   delay_ms(10);
   putc(stab);
   putc(17);
//   delay_ms(10);
   putc(y);
 //  delay_ms(10);
   putc(x);
 //  delay_ms(100);  //888888// removed this increase speed
   int8 nn;
   lcdSetCursorPos(0,0);
   for(nn=0;nn<<15;nn++)
   putc(' ');
if (onoff==0)
   putc(21);
   putc(0x08);
if (onoff==1)
   putc(21);
   putc(0x0c);
PostPosted: Thu Jun 02, 2005 1:08 pm     Reply with quote
PostPosted: Thu Jun 02, 2005 1:11 pm     Reply with quote
I don't know who posted that, but yes, I was wishing that the program
was a bit smaller and that he had posted his compiler version. Mr. Green
languer
PostPosted: Thu Jun 02, 2005 2:01 pm     Reply with quote
You say the posted (not small) program works with NOMCLR but does not with MCLR.
What is MCLR tied to (not floating I hope)?
What is the source for the interrupt (EXT/GP2)?
Hopefully you understand where I am headed with this (Pulse into GP2 -> MCLR on GP3 -> bad things happen if not properly isolated).
PostPosted: Thu Jun 02, 2005 2:20 pm     Reply with quote
the interrupt is GP2, the source of the interrupt is a square signal. the MCLR is not floating, it is connected with +5V.
DragonPIC
PostPosted: Thu Jun 02, 2005 2:26 pm     Reply with quote
#include <12f675.h>
I compile ok first time. Played around a little. Compiled again and error = "Missing #ENDIF". Probably not your problem, but an error.
-Matt
DragonPIC
PostPosted: Thu Jun 02, 2005 3:00 pm     Reply with quote
My compiler ver 3.178 compiles ok and I can see in the cof file that MCLRE bit changed correctly with MCLR and NOMCLR.
-Matt
DragonPIC
PostPosted: Thu Jun 02, 2005 3:18 pm     Reply with quote
try using INT_RA0, INT_RA1, ect for interrupts. I see them defined in the device library file.
-Matt
