young
how to set 12f675 MCLR pin? |
Posted: Thu Jun 02, 2005 11:14 am |
I want to use the PIN_A3 as a reset pin (12f675), so that when I trigger this pin, the chip will reset and start again, How can I do it< I did not find the related command in ccs c. thank you |
young
Posted: Thu Jun 02, 2005 12:04 pm |
I used MCLR for the other chips, it works fine, when I used for the 12f675, my other function like external interrupt stop working, any possible reasons? |
Posted: Thu Jun 02, 2005 12:28 pm |
Post a small complete program that shows the problem.
Be sure to post the #fuses statement, #use statements, etc.
Also post your version of the CCS compiler. |
young
Posted: Thu Jun 02, 2005 12:40 pm |
thank you, here is the whole program:
#if defined(__PCM__)
#include <12f675.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,MCLR
#use rs232(baud=9600, parity=N, xmit=PIN_A0,INVERT)
void LCDSetGeometry();
void LCDReset();
void LCDinit();
void LCDSetBackLight(int8 backlit);
void LCDSetContrast(int8 contr);
void LCDClrScr();
void LCDNewLine();
void LCDCR();
void LCDTab();
void LCDVerTab();
void LCDBackSpaces(int8 bspa);
void LCDSetTab(int8 Stab);
void LCDSetCursorPos(int8 x, int8 y);
void LCDClrLine(int8 x, int8 y);
void LCDSetCursorStyle();
void LCDOnOff(int8 onoff);
int16 count;
#INT_ext
void ext_isr()
count++;
setup_adc_ports (NO_ANALOGS);
setup_comparator(NC_NC_NC_NC); //setup_comparators(NC_NC_NC_NC); no "s"
LCDinit();
LCDClrScr();
LCDSetCursorPos(0,0);
puts("*Pulse counting*");
count=0;
EXT_INT_EDGE(L_TO_H);
enable_interrupts(INT_ext);
if(input(PIN_A1))
count=0;
LCDSetCursorPos(1,1);
printf("Num=%lu ",count);
putc(15);
delay_ms(10);
putc(16);
delay_ms(10);
putc(0x80);
delay_ms(10);
putc(0xc0);
delay_ms(10);
putc(0x80);
delay_ms(10);
putc(0x80);
delay_ms(10);
void LCDReset()
putc(14);
void LCDinit()
// Set LCD Geometry
LCDSetGeometry();
// LCDReset
LCDReset();
putc(20);
delay_ms(10);
putc(backlit);
putc(19);
delay_ms(10);
putc(contr);
void LCDClrScr()
putc(12);
delay_ms(10);
void LCDNewLine()
putc(10);
delay_ms(10);
void LCDCR()
putc(10);
void LCDTab()
putc(9);
void LCDVerTab()
putc(11);
int8 i;
for(i=1;i<bspa;i++)
putc(8);
stab=(stab^0xFF)+1;
putc(16);
delay_ms(10);
putc(stab);
putc(17);
// delay_ms(10);
putc(y);
// delay_ms(10);
putc(x);
// delay_ms(100); //888888// removed this increase speed
int8 nn;
lcdSetCursorPos(0,0);
for(nn=0;nn<<15;nn++)
putc(' ');
if (onoff==0)
putc(21);
putc(0x08);
if (onoff==1)
putc(21);
putc(0x0c);
Posted: Thu Jun 02, 2005 1:08 pm |
PCM programmer wrote: | Post a small complete program that shows the problem.
Posted: Thu Jun 02, 2005 1:11 pm |
I don't know who posted that, but yes, I was wishing that the program
was a bit smaller and that he had posted his compiler version. ![Mr. Green](images/smiles/icon_mrgreen.gif) |
languer
Posted: Thu Jun 02, 2005 2:01 pm |
You say the posted (not small) program works with NOMCLR but does not with MCLR.
What is MCLR tied to (not floating I hope)?
What is the source for the interrupt (EXT/GP2)?
Hopefully you understand where I am headed with this (Pulse into GP2 -> MCLR on GP3 -> bad things happen if not properly isolated). |
Posted: Thu Jun 02, 2005 2:20 pm |
the interrupt is GP2, the source of the interrupt is a square signal. the MCLR is not floating, it is connected with +5V. |
DragonPIC
Posted: Thu Jun 02, 2005 2:26 pm |
#include <12f675.h>
I compile ok first time. Played around a little. Compiled again and error = "Missing #ENDIF". Probably not your problem, but an error. _________________ -Matt |
DragonPIC
Posted: Thu Jun 02, 2005 3:00 pm |
My compiler ver 3.178 compiles ok and I can see in the cof file that MCLRE bit changed correctly with MCLR and NOMCLR. _________________ -Matt |
DragonPIC
Posted: Thu Jun 02, 2005 3:18 pm |
try using INT_RA0, INT_RA1, ect for interrupts. I see them defined in the device library file. _________________ -Matt |
