32bit value
stma
32bit value
PostPosted: Fri May 20, 2005 5:17 am     Reply with quote
I am trying to read in some 8bit values from a Xilinx CPLD. I have no problem reading in the individual bytes and displaying them. What I would like to do is convert the four bytes into a 32 bit integer. The code below only displays 00000000. The individual parts display fine as seen in the second for loop. Im sure its something basic so I apologise in advance but any help is greatly appreciated. Pic is a 16F877A
#include "C:\MYRTLEIII\MLog3_test2\Mlog3_test2.h"
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
void read1();
void read2();
void ShutDown();
#int_EXT
EXT_isr()
   read1();
   //read2();
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
   set_tris_d(0xff);
   set_tris_e(0x00);
   set_tris_a(0x00);
   porta=0x00;
   ShutDown();
void read1()
   int n;
   int8 in;
   int32 pressure=0;
   porta=0x01; //chooses one source from another
// problems with this below
   for(n=4;n!=0;n--)
      porte=n-1; //select bits for individual bytes from cpld
      in=portd;
      pressure=((pressure<<(8*n)) & in);
   printf("%lx ",pressure);
//This below works fine
   for(n=8;n!=4;n--)
      porte=n-1;
      in=portd;
      printf("%2x",in);
   printf("\n\r");
   return;
void ShutDown()
   printf("\n\r!!SLEEP!! \n\r");
     porta=0x00;
     sleep();
PostPosted: Fri May 20, 2005 5:27 am     Reply with quote
replace
by
      pressure= (pressure<<8) | in);
stma
PostPosted: Fri May 20, 2005 5:53 am     Reply with quote
Thanks a lot. Works perfectly. (and makes sense when I think about it now!!)
PostPosted: Fri May 20, 2005 6:06 am     Reply with quote
As a alternative way of doing it, which will be faster, consider this:
void read1()
   int n;
   union {
      int32 pressure;
      int8 b[4];
   } pval;
   for (n=4;n!=0;) {
      porte=--n;
      pval.b[n]=portd;
  printf("%lx ",pval.pressure;
This just writes the inputs directly into the bytes, instead of rotating the 32bit word multiple times.
PostPosted: Mon May 23, 2005 12:58 am     Reply with quote
Thanks very much,
I'll give it a go.
Cheers
