stma
32bit value |
Posted: Fri May 20, 2005 5:17 am |
I am trying to read in some 8bit values from a Xilinx CPLD. I have no problem reading in the individual bytes and displaying them. What I would like to do is convert the four bytes into a 32 bit integer. The code below only displays 00000000. The individual parts display fine as seen in the second for loop. Im sure its something basic so I apologise in advance but any help is greatly appreciated. Pic is a 16F877A
Code: | #include "C:\MYRTLEIII\MLog3_test2\Mlog3_test2.h"
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
void read1();
void read2();
void ShutDown();
#int_EXT
EXT_isr()
read1();
//read2();
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_EXT);
set_tris_d(0xff);
set_tris_e(0x00);
set_tris_a(0x00);
porta=0x00;
ShutDown();
void read1()
int n;
int8 in;
int32 pressure=0;
porta=0x01; //chooses one source from another
// problems with this below
for(n=4;n!=0;n--)
porte=n-1; //select bits for individual bytes from cpld
in=portd;
pressure=((pressure<<(8*n)) & in);
printf("%lx ",pressure);
//This below works fine
for(n=8;n!=4;n--)
porte=n-1;
in=portd;
printf("%2x",in);
printf("\n\r");
return;
void ShutDown()
printf("\n\r!!SLEEP!! \n\r");
porta=0x00;
sleep();
Posted: Fri May 20, 2005 5:27 am |
replace Code: | pressure=((pressure<<(8*n)) & in);
by Code: | pressure= (pressure<<8) | in);
stma
Posted: Fri May 20, 2005 5:53 am |
Thanks a lot. Works perfectly. (and makes sense when I think about it now!!) |
Posted: Fri May 20, 2005 6:06 am |
As a alternative way of doing it, which will be faster, consider this:
void read1()
int n;
union {
int32 pressure;
int8 b[4];
} pval;
for (n=4;n!=0;) {
porte=--n;
pval.b[n]=portd;
printf("%lx ",pval.pressure;
This just writes the inputs directly into the bytes, instead of rotating the 32bit word multiple times.
Posted: Mon May 23, 2005 12:58 am |
Thanks very much,
I'll give it a go.
Cheers |
