Jump out from while on interrupt
Goto page 1, 2, 3  Next
Tester21
PostPosted: Wed May 04, 2005 6:25 am     Reply with quote
sec=0;
while(sec < 15 && value !=0)
 printf(lcd_putc,"\f Timeout over ! First option);
 delay_ms(200);
printf(lcd_putc,"\fSecond option");function();
After 15 seconds you get displayed "second option" and this is ok.
What i want to do is to check if the button interrupt
( within this 15 second ) is triggered so i can ( before this 15 seconds timeout ) start with other function.
Instead, im looping in while and the value will never be "1" so i must allways wait till 15 seconds are out...
I must start function on two different ways (either thru timeout or button click, within this timeout)..
John
PostPosted: Wed May 04, 2005 7:05 am     Reply with quote
sec=0;
 delay_ms(200);
 if (button()) break;
Obviously you need a suitable test function (calld 'button' in the example), which returns 'true' when a button is hit, but this will prematurely exit the while, if the condition is met.
DragonPIC
PostPosted: Wed May 04, 2005 10:01 am     Reply with quote
You must set a flag in interrupt (as long as the input you have is capable of requesting an interrupt.)
For example, if I have the button connected to port b pin 0 and have configured the pin for interrupt, I could make an interrupt function:
int flags;
#bit button_flag = flags.0
#INT_ETX  //external interupt port b pin 0 on 16F876A
void button_int(void)
 button_flag = 1
sec=0;
button_flag = 0;
 delay_ms(200);
 if(button_flag) break;
Not sure if the interrupt is properly debounced for a button, so a delayed check may be necessary.
#BYTE port_b = 6
#BIT intr = port_b.0
for (i=1;i<100;i++)  //insert this in your interrupt before setting flag
 if(intr == 0) return;  //false alarm will return from interrupt without setting flag.
or
delay_us(25);
should do and would assume a high to cause interrupt. If button is grounded to cause interrupt change to:
 if(intr) return;  //false alarm will return from interrupt without setting flag.
Port b would of coarse have to be initialized for interrupts for rising (button causes high) or falling (button causes low) edges.
-Matt
DragonPIC
PostPosted: Wed May 04, 2005 10:09 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=22738
Check this thread for precautions on using the interrupt method.
-Matt
Tester21
PostPosted: Thu May 05, 2005 4:44 am     Reply with quote
I have button (pull up) on connected on port A on A3 and chip is 16F877
On this port there is no external interrupt but i have to trigger it :-(
Wenn i test the program, nothing happens (it's the same as before ).
After timeout is over second option is triggered, but i can't break the timeout.
#BYTE port_a = 3
#bit intr = port_a.0
int flags;
#INT_EXT
 button_flag = 1;
 delay_us(25);
sec=0;
button_flag = 0;
 delay_ms(200);
void main (void)
   //clear_interrupts(INT_EXT);
   enable_interrupts(INT_EXT);
do i get this error becuse of the A3 pin or do i miss this initialisation part
John
Tester21
#BYTE port_a = 3
int flags;
#INT_EXT
 button_flag = 1;
 delay_us(25);
sec=0;
button_flag = 0;
 delay_ms(200);
void main (void)
John
PostPosted: Fri May 06, 2005 11:09 am     Reply with quote
#INT_EXT can only be used with an external interrupt (pin B0). If you have the button connected to A3, you need to use Ttelmah's method.
#BYTE port_a = 5
#bit intr = port_a.3
sec=0;
 delay_ms(200);
short button(void)
 if(a3 == 1)
   delay_us(20);
   if(a3 == 1);
     return(1);
 return(0);
Would be the way to do it.
PostPosted: Fri May 06, 2005 11:28 am     Reply with quote
this post shows a nice way to debounce a button too.
http://www.ccsinfo.com/forum/viewtopic.php?t=22109&postdays=0&postorder=asc&start=15
Tester21
PostPosted: Sat May 07, 2005 4:27 am     Reply with quote
Ok. One small thing.. You have defined (a3==1). Is this right sintax or do i have to define some new variable to access intr... ?
John
Humberto
PostPosted: Sat May 07, 2005 8:47 am     Reply with quote
No. he had defined
Then tryied to acces that pin using:
short button(void)
  if(a3 == 1)
     delay_us(20);
     if(a3 == 1);
       return(1);
  return(0);
which is wrong.
To access such pin:
short button(void)
 if(intr)
    delay_us(20);
    if(intr)
      return(1);
   return(0);
But if you expect that this code will debounce the switch contacts, 20us is not enough.
Depending of the switch you are using, it will still bouncing up to 50ms after toggled.
So if your application is not time sensitive, use a longer delay.
short button(void)
 if(intr)
    delay_ms(50);
    if(intr)
       return(1);
       return(0);
You didnīt mention how do you connected the switch, but to run this code it is necesary a pull down
resistor connected between PIN_A3 and Gnd, then your switch connected between PIN_A3 and +5V.
Hope this help you,
Humberto
Tester21
PostPosted: Mon May 09, 2005 6:36 am     Reply with quote
The first switch is pull up and the second is pull down.
Hardware connection from A3 to gnd:
1.) PIN A3
2.) Resistor ( 50 K )
3.) switch
4.) gnd
I compile the program but there is no response on clicking the "A3" button in the timeout part.. Confused
John
Humberto
PostPosted: Mon May 09, 2005 6:58 am     Reply with quote
Donīt understand your description, but this is a pull down. Wire this and before testing any code
-using a scope or a multimeter- whatīs going on with the level in PIN_A3 when you push the button.
             ______________ +5V
          _| °  Button
             |_____________ PIN_A3
             /   R 10K
             |_____________ Gnd
Humberto
DragonPIC
PostPosted: Mon May 09, 2005 2:46 pm     Reply with quote
Thanks Humberto for the corrections.
-Matt
DragonPIC
PostPosted: Mon May 09, 2005 3:00 pm     Reply with quote
even better debounce would be:
short button(void)
   int cnt;
   while(intr)
     delay_us(5); //
     cnt++;
     if(cnt == 25)
        return(1);
   return(0);
you should be able to detect a bounce by the time you return.
-Matt
Humberto
PostPosted: Mon May 09, 2005 3:57 pm     Reply with quote
Hi DragonPIC,
Take in mind that the poster problem was that he canīt detect the pushbutton
action at all and I focused the help in the hardware and not in the best way to
debounce a switch contact.
If you want to know my opinion regarding code for debouncing, by far the best way is
using interrupts:
The level change impossed by the switch action is detected by any of the uC external
hardware interrupts, inside the interrupt clear a global counter and enable one timer,
wich every time it overflows increment the counter, after n counts bit test if the switch
had changed to confirm that the toggle was done, if yes just disable the timer interrupt.
You get a clean and efective debouncing technique without overhead nor wasting
time in delays while you have been running other code in the main.
Best wishes,
Humberto
Page 1 of 3
