returning float union
alexz
PostPosted: Fri Apr 22, 2005 6:33 am     Reply with quote
I have got a definition of the following union:
extern union unionFloat
float fl;
unsigned char cha[4];
extern union unionFloat AvStepsPerMm;
extern union unionFloat AvStepsPerMm_inv;
Then I have got a function:
unsigned float getAvStepsPerMm(void)
uchar i;
for (i=0;i<4;i++)
if ((AvStepPerMm.cha[i] ^ AvStepPerMm_inv.cha[i]) != 0xFF)
systemAlarm(CRITICAL_FLOAT_FAILURE);
return(AvStepsPerMm.fl);
I call it here:
readSFlash(0x04, (uchar*)&verify.fl);
if (getAvStepsPerMm() != verify.fl)
I have got the following errors on the "if" statement:
Error [1128] compatible scalar operands required for comparison
Error [1122] scalar operand expected for '!' operator
Error [1117] scalar type expected in 'if' statement
Alex
Mark
PostPosted: Fri Apr 22, 2005 7:47 am     Reply with quote
Try declaring
as
alexz
PostPosted: Fri Apr 22, 2005 7:49 am     Reply with quote
Mark wrote:
Try declaring
as
already tried
Alex
Mark
PostPosted: Fri Apr 22, 2005 7:50 am     Reply with quote
Are you using the CCS compiler? I get an error if I try unsigned but otherwise it compiles just fine.
alexz
PostPosted: Fri Apr 22, 2005 7:55 am     Reply with quote
Actually C18 at the moment
Alex
Mark
PostPosted: Fri Apr 22, 2005 7:58 am     Reply with quote
Okay, how do you expect people to help when they assume that you are using CCS compiler!?!?! Mad Why are you asking these questions on the Microchip forum? Good luck and maybe someone else will waste time helping ya, I ain't Exclamation
alexz
PostPosted: Fri Apr 22, 2005 8:02 am     Reply with quote
Sorry
Alex
