alexz
returning float union |
Posted: Fri Apr 22, 2005 6:33 am |
I have got a definition of the following union:
extern union unionFloat
float fl;
unsigned char cha[4];
extern union unionFloat AvStepsPerMm;
extern union unionFloat AvStepsPerMm_inv;
Then I have got a function:
unsigned float getAvStepsPerMm(void)
uchar i;
for (i=0;i<4;i++)
if ((AvStepPerMm.cha[i] ^ AvStepPerMm_inv.cha[i]) != 0xFF)
systemAlarm(CRITICAL_FLOAT_FAILURE);
return(AvStepsPerMm.fl);
I call it here:
readSFlash(0x04, (uchar*)&verify.fl);
if (getAvStepsPerMm() != verify.fl)
I have got the following errors on the "if" statement:
Error [1128] compatible scalar operands required for comparison
Error [1122] scalar operand expected for '!' operator
Error [1117] scalar type expected in 'if' statement _________________ Alex |
Mark
Posted: Fri Apr 22, 2005 7:47 am |
Try declaring
Code: | unsigned float getAvStepsPerMm(void)
as
Code: | float getAvStepsPerMm(void)
alexz
Posted: Fri Apr 22, 2005 7:49 am |
Mark wrote: | Try declaring
as
already tried _________________ Alex |
Mark
Posted: Fri Apr 22, 2005 7:50 am |
Are you using the CCS compiler? I get an error if I try unsigned but otherwise it compiles just fine. |
alexz
Posted: Fri Apr 22, 2005 7:55 am |
Mark wrote: | Are you using the CCS compiler? I get an error if I try unsigned but otherwise it compiles just fine. |
Actually C18 at the moment _________________ Alex |
Mark
Posted: Fri Apr 22, 2005 7:58 am |
Okay, how do you expect people to help when they assume that you are using CCS compiler!?!?! Why are you asking these questions on the Microchip forum? Good luck and maybe someone else will waste time helping ya, I ain't |
alexz
Posted: Fri Apr 22, 2005 8:02 am |
Mark wrote: | Okay, how do you expect people to help when they assume that you are using CCS compiler!?!?! Why are you asking these questions on the Microchip forum? Good luck and maybe someone else will waste time helping ya, I ain't |
Sorry _________________ Alex |
