Routine for RS232
Goto page 1, 2  Next
JEliecer
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Routine for RS232
PostPosted: Sat Apr 16, 2005 1:07 pm     Reply with quote
I need your help.
I have a RS232 routine, but when I send a data by the RS232 to a PIC, the program is Stopped.
This is my code:
#include<18f448.h>
#include<stdlib.h>
#use delay(clock=10000000, RESTART_WDT)
#use RS232(BAUD=9600, BITS=8, PARITY=N, XMIT=PIN_C6, RCV=PIN_C7, RESTART_WDT)
#byte PORTC=0xf82
#include<math.h>
byte year,mes,dow,m_dia,hora,min,seg,sig;
char UNO,DOS,TRES,RAEY,MOY,cmd,x;
int t,i;
char c[];
#include<RTCDS12C887.C>// This is a library for a Real time clock
#include<DRIVERLCD.C>
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#int_rda
serial_recibido()
lcd_enviar(LCD_COMANDO,LCD_CURSOR_BLINK);
do
c[i]=getc(); // Get a char from the PC
delay_ms(10);
i+=1;
while (c[i]!=0);
lcd_putc("\f"); // Display it on the LCD
lcd_putc(c); // Display it on the LCD
delay_ms(8000);
lcd_enviar(LCD_COMANDO,LCD_DISPLAY_OFF);
lcd_enviar(LCD_COMANDO,LCD_DISPLAY_ON);
disable_interrupts(global);
disable_interrupts(int_rda);
return;
i=0;
rtc_inicio();
lcd_init();
restart_wdt();
set_tris_c(191);
restart_wdt();
enable_interrupts(global);
enable_interrupts(int_rda);
leer_f( m_dia, mes, year, sig,dow);
leer_h( hora, min, seg );
switch (dow)
case 1:printf(lcd_putc,"\f SUN"); break;
case 2: printf(lcd_putc,"\f MON"); break;
case 3: printf(lcd_putc,"\f TUE"); break;
case 4: printf(lcd_putc,"\f WED"); break;
case 5: printf(lcd_putc,"\f THU"); break;
case 6: printf(lcd_putc,"\f FRI"); break;
case 7: printf(lcd_putc,"\f SAT"); break;
printf(lcd_putc," %2X/%2X/20%2X\",m_dia,mes,year);
printf(lcd_putc,"\n %2X:%2X:%",hora,min,seg);
delay_ms(800);
rwyoung
PostPosted: Sat Apr 16, 2005 1:31 pm     Reply with quote
Spotted several issues.
1) Why do you keep calling enable_interrupts() inside your main's while(1) loop? Call these once before the while loop. The compiler generates the necessary code for entering and exiting the ISR to disable/re-enable interrupts.
2) DON'T do so much in your receive character interrupt. Interrupts should be very short, quick routines. Calling out to other functions, calling delay_ms().
3) When you leave your interrupt don't need to be disabling the interrupts. It makes no sense. See #1.
4) The "return" keyword is not necessary at the end of your uart receive ISR.
5) Your statment char c[] at the beginning of your program isn't allocating more than one byte for that array. Later in your ISR when you are indexing that array you are GUARANTEED to be stepping on other data. Not only did you not allocate memory for the array (so the compiler knows where to put other variables in RAM) you aren't testing the index variable "i" for boundary conditions.
6) USE THE "CODE" BUTTON. This preserves the formating of your code when posting. Just pasting it into your post, you loose the leading spaces/tabs on each line. Makes it much harder to read.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
JEliecer
Routine for Rs232
PostPosted: Mon Apr 18, 2005 8:25 am     Reply with quote
This is my new code:
#include<16f877a.h>
#include<stdlib.h>
#include<LCDPIC16E.C>   //Driver for lcd 2*24
#byte PORTC=7
#int_rda
serial_recibido()
      unsigned char c;
      c=getc();
      delay_ms(10);   //Send the char to the lcd
      lcd_putc(c);
   lcd_init();
   set_tris_c(176);
   lcd_putc("\   HOLA JORGE\n");
      restart_wdt();
but this code only allows me to see the first three characters of the received string.
What should I do to be able to see all the received characters?
Darren Rook
Re: Routine for Rs232
PostPosted: Mon Apr 18, 2005 8:55 am     Reply with quote
Get rid of the delay() inside your interrupt. While you are delaying inside your interrupt there are characters being received by your PICs usart peripheral, but since you are delaying and not pulling it out of the buffer there is a buffer overrun and the peripheral is shut off.
JEliecer
Routine for Rs232
PostPosted: Mon Apr 18, 2005 5:45 pm     Reply with quote
Thanks boys. Now, I have a routine for receive the characters from the rs232.
But now, I need to convert streams of numbers to whole numbers of 8 bits.
As I can record the data received in a variable, to transform it later into integers or long integers numbers....????
Jorge Eliécer Castro
"THE UNIVERSE FOREVER CONSPIRES SO THAT OUR DESIRES ARE WILL BE REALITY"
"EL UNIVERSO SIEMPRE CONSPIRA PARA QUE NUESTROS DESEOS SE HAGAN REALIDAD"
Darren Rook
PostPosted: Mon Apr 18, 2005 8:02 pm     Reply with quote
Yes, look at atoi()
JEliecer
PostPosted: Tue Apr 19, 2005 9:42 am     Reply with quote
I renewed my code in this way:
#include<18f448.h>
#include<stdlib.h>
#use delay(clock=20000000, RESTART_WDT)
#use RS232(BAUD=9600, BITS=7, PARITY=N, XMIT=PIN_C6, RCV=PIN_C7, RESTART_WDT)
//byte hora,min,seg;
//#include<DRIVERRTC.C>
#byte PORTC=0Xf82
char c;
int VECT[];
int i=0;
#int_rda
void RDA_isr()
   c=getc();
   lcd_putc(c);
   VECT[i]=atoi(c);    //this part
   lcd_putc(VECT[i]); //isn't
   i+=1;                   //functional
   lcd_init();
   set_tris_c(176);
   lcd_putc("\f   HOLA JORGE\n");
      restart_wdt();
I'm transmit strings of numbers and I need to convert it into integers.
But now, I can't watch the received data in the LCD.
How I can use the atoi(),atol(), and the atoi32() functions. to converts strings into integers.
I need your help.
Thanks in advanced by your help.
Mark
PostPosted: Tue Apr 19, 2005 10:08 am     Reply with quote
Um, atoi() converts a piece of text to a number. You usually write text to displays otherwise you might not see it. Also, atoi() takes a pointer to a null terminated string. You are passing it a char which is incorrect. I think what you probably want to do it receive the chars into an array and then convert that array to an integer.
DragonPIC
PostPosted: Tue Apr 19, 2005 11:50 am     Reply with quote
JEliecer wrote:
I need your help.
Come on vominos, everybody let's go. Come one lets get to it. Come one there's nothing to it.
Sorry, my daughter is always watching that Dora show.
You didn't listen to rwyoung "5) Your statment char c[] at the beginning of your program isn't allocating more than one byte for that array."
When initializing "int VECT[];", allocate some memory like "int VECT[16];" with the largest expected size string in mind for the array size.
-Matt
JEliecer
PostPosted: Tue Apr 19, 2005 6:07 pm     Reply with quote
This is a new code....
#include<18f448.h>
#include<stdlib.h>
#byte PORTC=0Xf82
byte c;
int j,i=0;
byte X[];
#int_rda
void RDA_isr()
   c=getc();
   if ((c>=0X30)&&(c<=0X39))
      i+=1;
      j=c&0b00001111;
      printf(lcd_putc,"%u",j);
      X[i]=c;
   i=0;
   lcd_init();
   set_tris_c(176);
   delay_ms(3000);
      restart_wdt();
With this code I can watch in the LCD all the characters that I send by the RS232 to the PIC. But it doesn't allow me to stay all the numbers in an array.
It alone allows to save two digits.
That I can make to save, for example 20 data in an array...???
Thanks you guys.
Mark
PostPosted: Tue Apr 19, 2005 8:05 pm     Reply with quote
So you convert it from a string, to a number, and then back to a string? Kind of inefficient don't you think.
JEliecer
Routine for Rs232
PostPosted: Wed Apr 20, 2005 7:45 am     Reply with quote
Yes, I want to do receive the chars into an array and then convert that array to an integer.
The string only have numbers.
But I can't do it. How can I do...???
Please help me boys.
Mark
PostPosted: Wed Apr 20, 2005 9:23 am     Reply with quote
As we "boys" have told you, use the atoi() function on the array of chars! Don't do it on every character, do it on the whole string. Clear as mudd yet?
DragonPIC
PostPosted: Thu Apr 21, 2005 9:26 am     Reply with quote
char c[4];
int num;
gets(c);   //gets a string from rs232 and will insert null termination at end of string with a \r sent at end of # from data supplier
num = atoi(c);   //converts string to int
printf(lcd_putc,"%u",num);   //sends number to lcd
and adjust the size of the array and size of num to fit the highest expected # received from RS232 port.
Notice that whatever is sending the data needs to send a return when all data is finished transmission. For example, on the other side of the rs232 (the transmitter) the code could be wriitten like this:
printf("255\r");
or
printf("%u\r",number);
Did this help?[/code]
-Matt
JEliecer
Routine for Rs232
PostPosted: Thu Apr 21, 2005 2:55 pm     Reply with quote
I need your help again....
I wrote the code with yours indications, but it doesn't still work correctly...
I no know where I should define the char C[4]
#include<18f448.h>
#include<stdlib.h>
#byte PORTC=0Xf82
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
byte i;
int indice;
static unsigned int V[20];
#int_rda
void RDA_isr()
   char c[20];
   int dir=0;
   do
      gets(c);
         i=c&0X0F;
         lcd_putc(i);
         V[dir]=i;
         dir++;
   while(c!=0);
   indice=dir;
   lcd_init();
   set_tris_a(0);
   set_tris_c(176);
      restart_wdt();
      for(i=0;i<=indice;i++)
         {lcd_putc("\f"); lcd_putc(V[i]); delay_ms(1500);}
I am sending the strings with the calculating HP 48G. How I can insert the character '\ r' at the end of the string with the calculator.
In the forever loop, I can't visualize the characters of the V [i] array.
When I test this program the "ASCII 127" appears in the first position of the Lcd.
How I can make to solve this problem...????
Goto page 1, 2  Next
Page 1 of 2
