If I choose menu Debugger -> Clear memory -> GPRs,
it would clear all General Purpose Registers.
Is there a way, to write a line of command in the code to perform that?
Posted: Tue Mar 15, 2005 9:24 am
You can use #zero_ram. It will create a lot of ASM code -- more than
one line. Some people report that it doesn't work properly on some
of the 18F chips.
Mark
Posted: Tue Mar 15, 2005 1:13 pm
Another problem with #zero_ram is that it will clear the registers on reset. This might not be desired.
