Can a variable be mapped to the upper nibble of a byte?
Posted: Thu Mar 03, 2005 10:26 am
I would like to define a variable to the upper nibble of Port B for the INT_RB interrupt. How can I define this instead of masking out the rest of the entire port B byte? For ex:
#byte port_b=0x06; // verify actual location in device's datasheet
unsigned char discs;
discs = port_b >> 4;
There is no masking necessary here. After a boolean, a char is the next size unit can get.
dan king
Posted: Thu Mar 03, 2005 12:10 pm
nothing is wrong with that, as a matter of fact that's how I'm currently doing it. I just wanted to know if there was a way to specify the port bits used as in the following, instead of starting at bit 0.
