Can a variable be mapped to the upper nibble of a byte?
dan king
PostPosted: Thu Mar 03, 2005 10:26 am     Reply with quote
I would like to define a variable to the upper nibble of Port B for the INT_RB interrupt. How can I define this instead of masking out the rest of the entire port B byte? For ex:
#byte discs = PORTB
#bit discs.0 = PORTB.4
#bit discs.1 = PORTB.5
#bit discs.2 = PORTB.6
#bit discs.3 = PORTB.7
Thanks in advance.
Dan
valemike
PostPosted: Thu Mar 03, 2005 11:14 am     Reply with quote
What's wrong with simply doing:
#byte port_b=0x06; // verify actual location in device's datasheet
unsigned char discs;
discs = port_b >> 4;
There is no masking necessary here. After a boolean, a char is the next size unit can get.
dan king
PostPosted: Thu Mar 03, 2005 12:10 pm     Reply with quote
nothing is wrong with that, as a matter of fact that's how I'm currently doing it. I just wanted to know if there was a way to specify the port bits used as in the following, instead of starting at bit 0.
struct {
BYTE data:4; // bits 0 - 3
BYTE regsel:1; // bit 4
BYTE read:1; // bit 5
} LCD_PORT;
#byte PORTB = 6 // port a = 0x05, b = 0x06
#BYTE LCD_PORT = 6
#BIT LCD_E = PORTB.6 // bit 6
#define LCD_RD LCD_PORT.read
#define LCD_RS LCD_PORT.regsel
#define LCD_DATA LCD_PORT.data
