Please Check My code (B0 Interrupt)
NewSpace
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Tue Feb 22, 2005 7:58 am     Reply with quote
Dear Master.
#include<16F874.h>
#device pic16f874 *=8 adc=10
int x, count, state;
void reset()
   state == 0;
   output_high(pin_C5);
   output_c(0x00);
   output_d(0x00);
   printf("%c%c%c",0xa1,0,1);
   printf("%c Stop               %c",0xa2, 0);
#INT_EXT
ext_isr()
   reset();
void cylinder1_Up()
   if(state == 0) break;
   output_low(pin_D0);
   while(!input(pin_A0)) {}
void cylinder1_Dn()
   output_high(pin_D0);
   while(input(pin_A0)) {}
void cylinder2_Up()
   output_low(pin_D1);
   while(input(pin_A1)) {}
void cylinder2_Dn()
   output_high(pin_D1);
   while(!input(pin_A1)) {}
void vacum1_ON()
   output_high(pin_D2);
void vacum1_OFF()
   output_low(pin_D2);
   output_high(pin_D3);
   delay_ms(200);
   output_low(pin_D3);
void servo_init()
   while(!input(pin_e1)) {}
   output_low(pin_D4);
   output_low(pin_D5);
   output_low(pin_D6);
   output_low(pin_D7);
   output_high(pin_C4);
   output_low(pin_C4);
   delay_ms(200);
   while(!input(pin_e2)){}
void Move_Home()
   output_high(pin_D4);
   output_low(pin_D5);
   output_low(pin_D6);
   output_low(pin_D7);
   output_low(pin_C4);
   delay_ms(200);
   while(!input(pin_e2)) {} }
void move_cpruf()
   output_low(pin_D4);
   output_high(pin_D5);
   output_low(pin_D6);
   output_low(pin_D7);
   output_low(pin_C4);
   delay_ms(200);
void move_tray_x()
   x = count%10;
   if(x == 1)
      output_low(pin_D6);
      output_low(pin_D7);
   else if(x == 2)
      output_low(pin_D4);
      output_low(pin_D5);
      output_high(pin_D6);
      output_low(pin_D7);
   else if(x == 3)
      output_low(pin_D5);
      output_low(pin_D7);
   else if(x == 4)
      output_low(pin_D4);
      output_low(pin_D7);
   else if(x == 5)
      output_low(pin_D7);
   else if(x == 6)
      output_low(pin_D4);
      output_low(pin_D5);
      output_low(pin_D6);
      output_high(pin_D7);
   else if(x == 7)
      output_low(pin_D5);
      output_low(pin_D6);
   else if(x == 8)
      output_low(pin_D4);
      output_low(pin_D6);
   else if(x == 9)
      output_low(pin_D6);
   else if(x == 0)
      output_low(pin_D4);
      output_low(pin_D5);
   output_low(pin_C4);
   delay_ms(200);
void cpruf()
   output_high(pin_c2);
   output_low(pin_c2);
   while(!input(pin_a5)) {}
void home()
   output_high(pin_c1);
   output_low(pin_c1);
void move_tray_y()
   if (count == 10 || count == 20 || count == 30 || count == 40 || count == 50 || count == 60 || count == 70 || count == 80 || count == 90)
      output_high(pin_C3); //Move Tray
      output_low(pin_C3);
   else if (count == 100)  //Go Home~!
      output_high(pin_C1);
      output_low(pin_C1);
      count = 1;
void start()
    move_home();
   cylinder1_dn();
   cylinder2_Dn();
   vacum1_ON();
   delay_ms(200);
   cylinder2_Up();
   delay_ms(200);
   move_cpruf();
   cylinder2_Dn();
   delay_ms(200);
   cpruf();
   cylinder2_Up();
   delay_ms(200);
   move_tray_x();
   cylinder2_Dn();
   vacum1_OFF();
   cylinder2_Up();
   cylinder1_up();
   move_home();
   else count = count + 1;
   move_tray_y();
   setup_adc_ports(NO_ANALOGS);
   ext_int_edge(0,L_TO_H);
   enable_interrupts(int_ext);
   enable_interrupts(global);
                        // 7 6 5 4 3 2 1 0
   set_tris_a(0x3F);    //     I I I I I I
   set_tris_b(0xFF);    // I I I I I I I I
   set_tris_c(0x00);    // O O O O O O O O
   set_tris_d(0x00);    // O O O O O O O O
   set_tris_e(0xFF);    //           I I I
   output_c(0x00);
   output_d(0x00);
   output_e(0x00);
   x = 0;
   count = 1;
   state = 0;
   output_high(pin_c0);
a:
      if(state == 0)
          if(input(pin_B1))   //Start?
            servo_init();
            home();
            state = 1;
      else if(state == 1)
         if(input(pin_B1)) start();
         else if(input(pin_B2)) cylinder1();
         else if(input(pin_B3)) cylinder2();
         else if(input(pin_B4)) Vacum1();
         else if(input(pin_B5)) Move_Home();
         else if(input(pin_B6)) Move_cpruf();
         else if(input(pin_B7)) Move_Tray_x();
When turn on power than state == 0
than if B1 on Init.... and one more if B1 on start...
when running B0 On... It's like E-Stop...
than push B1... than Start... But... It's can't running...
Please check code...
Hello~?
This is South KOREA
My name is Sanghyouk Kim But Call me Nick
Sorry I'm poor English
PostPosted: Tue Feb 22, 2005 11:10 am     Reply with quote
I did not check your whole program, but I did see one problem.
You have many functions like this:
void cylinder2_Dn()
The problem is in this statement:
This is not the correct way to use the "break" statement.
See the following link
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vccelng/htm/state_2.asp
I did not study your program in detail, but I think you probably
want to return from the function if the state is 0. So use the
"return" statement as shown below:
void cylinder2_Dn()
if(state == 0) return;
Your main problem is that you need to study the C language some more.
Before you use a statement, you need to look at example programs
and also to study the C manual.
NewSpace
I think...
PostPosted: Tue Feb 22, 2005 12:13 pm     Reply with quote
Sorry...
Ithink...
When push E-Stop button... than B0 on...
So...
void reset()
   state == 0;
   output_c(0x00);
   output_d(0x00);
#INT_EXT
ext_isr()
   reset();
and...
Push Start Button...
INIT..... ruturn...
Hello~?
This is South KOREA
PostPosted: Tue Feb 22, 2005 12:28 pm     Reply with quote
I cannot write your program for you. You must do it.
But you must study the C language more.
This statement does not set the variable "state" equal to 0.
state == 0;
You need to write it like this:
state = 0;
Please study the C language before you write more code.
