young
how to setup and measured the baud rate? |
Posted: Mon Jan 24, 2005 9:07 am |
I am think you setup baud rate and measure it, but How could I do it? |
Sherpa Doug Guest
Posted: Mon Jan 24, 2005 12:23 pm |
The most practical way is to use an oscilloscope. If you send a string of the character "U" it is real easy to see a bit length.
If you can't get a scope you could send a long string of maybe 1000 characters and time it with a stopwatch. |
Posted: Mon Jan 24, 2005 12:31 pm |
Thank you:
I am trying to use the wireless communication. so far for a near diatance it is working well, but a little bit farther, the data start to having delay and some noise. I am trying to intensify my signal to get stable data, and I hear that the baud rate is one of the issue.
I will try to see if baud rate keep stable using oscilloscope, if there is a little different between two chips (same as two 16f76 chips), is it able to calibrate them to same frequency?
what other ways to make a wireless communication more stable? |
rwyoung
Posted: Mon Jan 24, 2005 1:39 pm |
Google for "Manchester Encoding" _________________ Rob Young
young
Posted: Tue Jan 25, 2005 8:43 am |
I searched and take a home work at it and understand how manchester en/decoding working. I think it is just a software way to satblize the TX/RX remote communication/ are there any physical encoder/dedcorder that I can use? |
rwyoung
Posted: Tue Jan 25, 2005 11:19 am |
young wrote: | I searched and take a home work at it and understand how manchester en/decoding working. I think it is just a software way to satblize the TX/RX remote communication/ are there any physical encoder/dedcorder that I can use? |
Yes you can buy chips but probably most people implement the scheme in either programmable logic (CPLD or FPGA) or a microcontroller.
The general idea is to keep approximately the same number of 0 to 1 as 1 to 0 transitions so that your transmitter and or receiver never spend too long at a single level. Prevents possible saturation of the analog circuits and helps the receiving hardware extract the clock so that it can keep a lock on the data stream. _________________ Rob Young
