osccal register
chava
osccal register
PostPosted: Mon Feb 23, 2004 4:56 am     Reply with quote
Hello
I have a pic 16f630 which I erased its calibration data( the "retlw k" instruction in address 0x3ff)
I want to re-program that location
I want that in program memory address 0x3ff will be :"retlw 0x80"
I tryed:
#org 0x3fd,0x3ff
char const cal[1]={0x80};
but this generated the code:
address 0x3fd: addwf pcl,f
address 0x3fe: retlw0x80
address 0x3ff: retlw 0x0
I tryed :
#org 0x3ff
#asm
retlw 0x80
#endasm
but the compiler asked me about a decleration ("expecting a decleration")
how can I do that?
Doug
PostPosted: Mon Feb 23, 2004 12:49 pm     Reply with quote
If 0x80 is the factory calibration value then you can put this at the top of your program:
#ROM 0x3FF={0x3480}
0x3FF is the last program memory address if it is a 1K rom. A 2K rom will be 0x7FF and so on..
0X34 is the RETWL opcode.
0x80 is the factory calibration value.
Hope this helps.
Guard
PostPosted: Fri Jan 21, 2005 8:45 am     Reply with quote
hi,
Does the program function if retwl dosn't exist ? ( I erased all memory ) ???
Mark
PostPosted: Fri Jan 21, 2005 9:07 am     Reply with quote
If you use the internal OSC and that location is blank, then no. It will just loop. It expects a return there. The instuction will act as a NOP and the PC will roll to 0 and the program start over. Most programmers protect this space and won't even allow you to save to it.
