but the compiler asked me about a decleration ("expecting a decleration")
how can I do that?
Doug Guest
Posted: Mon Feb 23, 2004 12:49 pm
If 0x80 is the factory calibration value then you can put this at the top of your program:
#ROM 0x3FF={0x3480}
0x3FF is the last program memory address if it is a 1K rom. A 2K rom will be 0x7FF and so on..
0X34 is the RETWL opcode.
0x80 is the factory calibration value.
Hope this helps.
Guard
Posted: Fri Jan 21, 2005 8:45 am
hi,
Does the program function if retwl dosn't exist ? ( I erased all memory ) ???
Mark
Posted: Fri Jan 21, 2005 9:07 am
If you use the internal OSC and that location is blank, then no. It will just loop. It expects a return there. The instuction will act as a NOP and the PC will roll to 0 and the program start over. Most programmers protect this space and won't even allow you to save to it.
