MCR Guest
INHX8M file format |
Posted: Mon Jan 10, 2005 8:02 am |
I use a Velleman K8048 kit as a programmer with the programming software that came with it.
The programming software only accepts a INHX8M hex file.
How must i configure the CCS compiler to make a INHX8M as output file.
Martijn(Netherlands) |
Mark
Posted: Mon Jan 10, 2005 8:58 am |
That is the format of the hex file. |
Posted: Mon Jan 10, 2005 10:11 am |
still i get the message wrong file format from my programmer. It does work with another C compiler. |
Mark
Posted: Mon Jan 10, 2005 10:23 am |
From the help file
Quote: |
File Formats
The compiler can output 8 bit hex, 16 bit hex, and binary files. Two listing formats are available. Standard format resembles the Microchip tools and may be required by some third-party tools. The simple format is easier to read. The debug file may either be a Microchip .COD file or Advanced Transdata .MAP file. All file formats and extensions are selected via the Options|File Formats menu option in the Windows IDE.
And a quote from PCM Programmer
Quote: | Quote:
My programmer is writen for Hex codes generated by assembler, not C compiler. Does this matter? I had no trouble before when I used assembler. For programming convenience i'm trying move to C.
It will almost certainly work with Hex files generated by a compiler.
The only possible problem would be if your programmer doesn't like
the comment that CCS puts at the end of its Hex files. ie:
;PIC16F877
Most modern programmers don't complain about this. |
MCR Guest
Posted: Tue Jan 11, 2005 7:38 am |
Still get the same problem. I really got now idea how to fix this. Is there an easy DIY programmer that i can build to go with CCS? |
Posted: Tue Jan 11, 2005 8:15 am |
The CCS compiler generates an almost standard Intel Hex file and it shouldn't be a problem to read this into most programmers. One of the minor differences is the appended chip-id at the file end.
You don't give us any information, so we can't help you.
Information we are looking for is something like:
- What is the error message you get from your programmer?
- Do you get an immediate answer on loading the file by the programmer, or is it somewhere halfway the programming process?
- What exactly did you try to solve the problem?
- Did you try manually removing the chip-id from the hex-file? (the last line, starting with a ';' not a ':')
Which compiler environment (IDE) are you using? The CCS IDE or Microchip MPLAB?
What are the compiler settings for the output file type? 8- or 16bits hex file? |
Posted: Wed Jan 12, 2005 7:15 am |
Ok, here is some info:
I use MPlab with CCS PCWH as compiler
I get the message "Wrong file format" when try to open the hex file generated by ccs with the programmer software from Velleman(K8084 kit)
I tried to remove the ;pic id here but it did not work. I tried all setting si could make with ccs. 8 bit, 16 bit and some of the others settings, but i do not exactly know what they do. Is it possible to post both hex files so you guys can take a look at it? |
Mark
Posted: Wed Jan 12, 2005 8:14 am |
The CCS compiler is generating standard Intel hex-files and you are one of the few people having problems. My guess is that the Velleman software has some special requirements.
Quote: | Is it possible to post both hex files so you guys can take a look at it? | Yes this is possible. Please post both the hex-files from the other compiler that is working and the ccs-hex file. In order to prevent posting large files, just post from both hex-files the first and last 10 lines. |
Posted: Wed Jan 12, 2005 9:01 am |
The demo2 file from velleman:
:1000000012286430A1006430A00005181F2885184C
:100010001F2805191F2885191F28A00B0528A10BCB
:100020000328003407309F008316D73081008B01EE
:10003000C0308600FF308500831286017628860155
:100040000518292885184A2805196B288519762846
:100050001F2805182928203086000120303086000E
:1000600001203830860001203C30860001203E30DF
:10007000860001203F30860001203E3086000120AE
:100080003C30860001203830860001203030860068
:1000900001202B2885184A280130860001200230D3
:1000A00086000120043086000120083086000120EF
:1000B000103086000120203086000120103086009C
:1000C0000120083086000120043086000120023023
:1000D000860001204C2805196B2807308600012076
:1000E000012038308600012001206D2885197628EE
:1000F0000830860001200120003086000120012008
:0201000078285D
:02400E00613F10
:00000001FF
The ccs file:
:1000000000308A000428000084011F308305073077
:060010009F0009286300B7
:00000001FF
;PIC16F627
The ccs file contains this "program". I wanted to test the programming before i start my project so the program is very, very simple.
/*test.c*/
#INCLUDE <16f627.h>
void main ()
for(;;)
/*Very simple, nothing happens here!!*/
Mark
Posted: Wed Jan 12, 2005 9:06 am |
Worked for me. All I got was a warning about not having a config word in the file. |
MCR Guest
Posted: Wed Jan 12, 2005 9:09 am |
Must be the software from velleman than. Anyone here ever used the K8048 kit? |
Mark
Posted: Wed Jan 12, 2005 9:12 am |
Then go visit the link I posted and try out that software. It should be the same one that you have, ProgPic2?? |
Posted: Wed Jan 12, 2005 9:24 am |
So far so good Mark! Thanks for your help! |
MCR Guest
Posted: Wed Jan 12, 2005 9:26 am |
That is another version of ProgPicII i got with the kit(might be newer).
Is it possible that the missing config word is the problem? |
