INHX8M file format
Goto page 1, 2  Next
MCR
INHX8M file format
PostPosted: Mon Jan 10, 2005 8:02 am     Reply with quote
I use a Velleman K8048 kit as a programmer with the programming software that came with it.
The programming software only accepts a INHX8M hex file.
How must i configure the CCS compiler to make a INHX8M as output file.
Martijn(Netherlands)
Mark
PostPosted: Mon Jan 10, 2005 8:58 am     Reply with quote
That is the format of the hex file.
PostPosted: Mon Jan 10, 2005 10:11 am     Reply with quote
still i get the message wrong file format from my programmer. It does work with another C compiler.
Mark
PostPosted: Mon Jan 10, 2005 10:23 am     Reply with quote
From the help file
File Formats
The compiler can output 8 bit hex, 16 bit hex, and binary files. Two listing formats are available. Standard format resembles the Microchip tools and may be required by some third-party tools. The simple format is easier to read. The debug file may either be a Microchip .COD file or Advanced Transdata .MAP file. All file formats and extensions are selected via the Options|File Formats menu option in the Windows IDE.
And a quote from PCM Programmer
My programmer is writen for Hex codes generated by assembler, not C compiler. Does this matter? I had no trouble before when I used assembler. For programming convenience i'm trying move to C.
It will almost certainly work with Hex files generated by a compiler.
The only possible problem would be if your programmer doesn't like
the comment that CCS puts at the end of its Hex files. ie:
;PIC16F877
Most modern programmers don't complain about this.
MCR
PostPosted: Tue Jan 11, 2005 7:38 am     Reply with quote
Still get the same problem. I really got now idea how to fix this. Is there an easy DIY programmer that i can build to go with CCS?
PostPosted: Tue Jan 11, 2005 8:15 am     Reply with quote
The CCS compiler generates an almost standard Intel Hex file and it shouldn't be a problem to read this into most programmers. One of the minor differences is the appended chip-id at the file end.
You don't give us any information, so we can't help you.
Information we are looking for is something like:
- What is the error message you get from your programmer?
- Do you get an immediate answer on loading the file by the programmer, or is it somewhere halfway the programming process?
- What exactly did you try to solve the problem?
- Did you try manually removing the chip-id from the hex-file? (the last line, starting with a ';' not a ':')
Which compiler environment (IDE) are you using? The CCS IDE or Microchip MPLAB?
What are the compiler settings for the output file type? 8- or 16bits hex file?
PostPosted: Wed Jan 12, 2005 7:15 am     Reply with quote
Ok, here is some info:
I use MPlab with CCS PCWH as compiler
I get the message "Wrong file format" when try to open the hex file generated by ccs with the programmer software from Velleman(K8084 kit)
I tried to remove the ;pic id here but it did not work. I tried all setting si could make with ccs. 8 bit, 16 bit and some of the others settings, but i do not exactly know what they do. Is it possible to post both hex files so you guys can take a look at it?
Mark
PostPosted: Wed Jan 12, 2005 7:45 am     Reply with quote
I went here http://www.speedy-bl.com/pic16fxxx-e.htm and downloaded ProgPic2 and had no problems opening a hex file with the software.
PostPosted: Wed Jan 12, 2005 8:14 am     Reply with quote
The CCS compiler is generating standard Intel hex-files and you are one of the few people having problems. My guess is that the Velleman software has some special requirements.
Yes this is possible. Please post both the hex-files from the other compiler that is working and the ccs-hex file. In order to prevent posting large files, just post from both hex-files the first and last 10 lines.
PostPosted: Wed Jan 12, 2005 9:01 am     Reply with quote
The demo2 file from velleman:
:1000000012286430A1006430A00005181F2885184C
:100010001F2805191F2885191F28A00B0528A10BCB
:100020000328003407309F008316D73081008B01EE
:10003000C0308600FF308500831286017628860155
:100040000518292885184A2805196B288519762846
:100050001F2805182928203086000120303086000E
:1000600001203830860001203C30860001203E30DF
:10007000860001203F30860001203E3086000120AE
:100080003C30860001203830860001203030860068
:1000900001202B2885184A280130860001200230D3
:1000A00086000120043086000120083086000120EF
:1000B000103086000120203086000120103086009C
:1000C0000120083086000120043086000120023023
:1000D000860001204C2805196B2807308600012076
:1000E000012038308600012001206D2885197628EE
:1000F0000830860001200120003086000120012008
:0201000078285D
:02400E00613F10
:00000001FF
The ccs file:
:1000000000308A000428000084011F308305073077
:060010009F0009286300B7
:00000001FF
;PIC16F627
The ccs file contains this "program". I wanted to test the programming before i start my project so the program is very, very simple.
/*test.c*/
#INCLUDE <16f627.h>
void main ()
for(;;)
/*Very simple, nothing happens here!!*/
Mark
PostPosted: Wed Jan 12, 2005 9:06 am     Reply with quote
Worked for me. All I got was a warning about not having a config word in the file.
MCR
PostPosted: Wed Jan 12, 2005 9:09 am     Reply with quote
Must be the software from velleman than. Anyone here ever used the K8048 kit?
Mark
PostPosted: Wed Jan 12, 2005 9:12 am     Reply with quote
Then go visit the link I posted and try out that software. It should be the same one that you have, ProgPic2??
PostPosted: Wed Jan 12, 2005 9:24 am     Reply with quote
So far so good Mark! Thanks for your help!
MCR
PostPosted: Wed Jan 12, 2005 9:26 am     Reply with quote
That is another version of ProgPicII i got with the kit(might be newer).
Is it possible that the missing config word is the problem?
Goto page 1, 2  Next
Page 1 of 2
