In a recent application, I used MAXIM MAX-233 which is a MAX-232 with built in caps.
233 is bigger than 232, it means that obviuosly pinouts are not compatible. but it works fine. Take a look at the prices: the cost of the single chip MAX233 is higher, but if you use MAX232 you have to add caps costs and time to solder them!
