I would like to build a data acquisition using PIC. Data will be sent to a computer using RS232/ UART, say 2kByte/s. The test data is a sine wave from a signal generator.
Since the application is to receive real time signal, can anyone suggests a way to transfer the data so that no data lag in between?
What is the way that is usually being used? _________________ Einly
Posted: Mon Nov 15, 2004 5:12 am
Have your PIC add a timestamp to the data, any delays in transmitting the data will be no problem after that.
