problem with pointers
treitmey
PostPosted: Thu Nov 11, 2004 11:03 am     Reply with quote
I have a problem with this code. Can someone see the error?
ccs ver 3.212 and a 16f877 @ 16MhZ
When I step through it, the watch window is correct. But on the rs232 debug window, I don't get 70,80,90 as I expect.
#include <16F877.h>
#device *=16
#include <string.h> //for memcmp
#case
#use delay(clock=16000000)
#ZERO_RAM
#define VER_MAJOR 1
#define VER_MINOR 00
#use rs232(baud=57600,xmit=PIN_A2,INVERT,stream=DEBUG)
struct  pkt
  BYTE type;
  BYTE data[25];
struct pkt Pkt0,Pkt1,Pkt2,Pkt3;
struct pkt *p_pkt[4];
#define TXSIZE   32
#define TXMASK TXSIZE-1
int8 TX_BUF[TXSIZE];
int8 tx_indx_i,tx_indx_o;
#define RXSIZE   16
#define RXMASK RXSIZE-1
int8 RX_BUF[RXSIZE];
int8 rx_indx_i=0,rx_indx_o=0;
//======================= MAIN ============================//
  setup_adc_ports(NO_ANALOGS);
  set_tris_a(0xFF);
  set_tris_b(0xFF);
  set_tris_c(0xFF);
  set_tris_d(0xFF);
  set_tris_e(0xFF);
  p_pkt[0]=&Pkt0;
  p_pkt[1]=&Pkt1;
  p_pkt[2]=&Pkt2;
  p_pkt[3]=&Pkt3;
  //--------- START -------//
  fprintf(DEBUG,"STARTING U11\n\r");
  fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
  Pkt0.type =  0x10;
  Pkt0.data[0]=0x20;
  Pkt0.data[1]=0x30;
  Pkt1.type =  0x70;
  Pkt1.data[0]=0x80;
  Pkt1.data[1]=0x90;
  fprintf(DEBUG,"%X %X %X\n\r",Pkt0.type,Pkt0.data[0],Pkt0.data[1]);
  fprintf(DEBUG,"%X %X %X\n\r",Pkt1.type,Pkt1.data[0],Pkt1.data[1]);
  fprintf(DEBUG,"----------\n\r");
  fprintf(DEBUG,"%X \n\r",p_pkt[0]->type);
  fprintf(DEBUG,"%X \n\r",p_pkt[0]->data[0]);
  fprintf(DEBUG,"%X \n\r",p_pkt[0]->data[1]);
  fprintf(DEBUG,"%X \n\r",p_pkt[1]->type);
  fprintf(DEBUG,"%X \n\r",p_pkt[1]->data[0]);
  fprintf(DEBUG,"%X \n\r",p_pkt[1]->data[1]);
while(1){}
Mark
PostPosted: Thu Nov 11, 2004 1:11 pm     Reply with quote
#include <16F877.h>
#device *=16
#case
#ZERO_RAM
#define VER_MAJOR 1
#use rs232(baud=57600,xmit=PIN_A2, INVERT, stream=DEBUG)
struct  pkt
  BYTE type;
  BYTE data[25];
struct pkt* p_pkt[4];
#define TXSIZE   32
#define RXSIZE   16
  set_tris_a(0xFF);
  set_tris_b(0xFF);
  set_tris_c(0xFF);
  set_tris_d(0xFF);
  set_tris_e(0xFF);
  p_pkt[0]=&Pkt0;
  p_pkt[1]=&Pkt1;
  p_pkt[2]=&Pkt2;
  p_pkt[3]=&Pkt3;
  Pkt0.type =  0x10;
  Pkt0.data[0]=0x20;
  Pkt0.data[1]=0x30;
  Pkt1.type =  0x70;
  Pkt1.data[0]=0x80;
  Pkt1.data[1]=0x90;
  fprintf(DEBUG,"%X \n\r",(p_pkt[0])->type);
  fprintf(DEBUG,"%X \n\r",(p_pkt[0])->data[0]);
  fprintf(DEBUG,"%X \n\r",(p_pkt[0])->data[1]);
  fprintf(DEBUG,"%X \n\r",(p_pkt[1])->type);
  fprintf(DEBUG,"%X \n\r",(p_pkt[1])->data[0]);
  fprintf(DEBUG,"%X \n\r",(p_pkt[1])->data[1]);
while(1){}
treitmey
PostPosted: Thu Nov 11, 2004 1:30 pm     Reply with quote
THANKS, THANKS,THANKS, THANKS,THANKS, THANKS!
order of evaluation, I get it...
never saw that comming.
Mark
PostPosted: Thu Nov 11, 2004 2:37 pm     Reply with quote
Welcome, welcome, welcome.
treitmey
PostPosted: Thu Nov 11, 2004 3:59 pm     Reply with quote
Perhaps someone can help me on this also. Why won't this work. : (
#include <16F877.h>
#device *=16
#case
#ZERO_RAM
#define VER_MAJOR 1
struct  pkt
  BYTE type;
  BYTE data[25];
struct pkt * p_pkt[4];
//4 structs and an array of 4 pointers to the stucts
  int8 i,n;
  set_tris_a(0xFF);
  set_tris_b(0xFF);
  set_tris_c(0xFF);
  set_tris_d(0xFF);
  set_tris_e(0xFF);
  p_pkt[0]=&Pkt0;
  p_pkt[1]=&Pkt1;
  p_pkt[2]=&Pkt2;
  p_pkt[3]=&Pkt3;
  Pkt0.data[1]=0x1;
  Pkt1.data[1]=0x2;
  Pkt2.data[1]=0x3;
  Pkt3.data[1]=0x4;
  fprintf(DEBUG,"%X %X %X %X\n\r",Pkt0.data[1],Pkt1.data[1],Pkt2.data[1],Pkt3.data[1]);
  for (i=0;i<4;i++)
    fprintf(DEBUG,"%X \n\r",(p_pkt[i])->data[1]);
while(1){}
treitmey
PostPosted: Thu Nov 11, 2004 5:27 pm     Reply with quote
Can I simply not have 4 structs and a 4 elliment array of pointers to the struct?
Mark
PostPosted: Thu Nov 11, 2004 8:22 pm     Reply with quote
Just a stinky compiler Confused
  for (i=0;i<4;i++)
    fprintf(DEBUG,"%X \n\r", ((struct pkt*)p_pkt[i])->data[1]);
treitmey
PostPosted: Fri Nov 12, 2004 8:16 am     Reply with quote
So if i understand.
You typecast p_pkt to be of type pointer to struc pkt.
and then you wraped the part in front of the structure pointer operator '->'
Got it.
Mark
PostPosted: Fri Nov 12, 2004 8:38 am     Reply with quote
You got it. Very Happy
