treitmey
| problem with pointers |
Posted: Thu Nov 11, 2004 11:03 am |
I have a problem with this code. Can someone see the error?
ccs ver 3.212 and a 16f877 @ 16MhZ
When I step through it, the watch window is correct. But on the rs232 debug window, I don't get 70,80,90 as I expect.
| Code: | #include <16F877.h>
#device *=16
#include <string.h> //for memcmp
#case
#use delay(clock=16000000)
#ZERO_RAM
#define VER_MAJOR 1
#define VER_MINOR 00
#use rs232(baud=57600,xmit=PIN_A2,INVERT,stream=DEBUG)
struct pkt
BYTE type;
BYTE data[25];
struct pkt Pkt0,Pkt1,Pkt2,Pkt3;
struct pkt *p_pkt[4];
#define TXSIZE 32
#define TXMASK TXSIZE-1
int8 TX_BUF[TXSIZE];
int8 tx_indx_i,tx_indx_o;
#define RXSIZE 16
#define RXMASK RXSIZE-1
int8 RX_BUF[RXSIZE];
int8 rx_indx_i=0,rx_indx_o=0;
//======================= MAIN ============================//
setup_adc_ports(NO_ANALOGS);
set_tris_a(0xFF);
set_tris_b(0xFF);
set_tris_c(0xFF);
set_tris_d(0xFF);
set_tris_e(0xFF);
p_pkt[0]=&Pkt0;
p_pkt[1]=&Pkt1;
p_pkt[2]=&Pkt2;
p_pkt[3]=&Pkt3;
//--------- START -------//
fprintf(DEBUG,"STARTING U11\n\r");
fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
Pkt0.type = 0x10;
Pkt0.data[0]=0x20;
Pkt0.data[1]=0x30;
Pkt1.type = 0x70;
Pkt1.data[0]=0x80;
Pkt1.data[1]=0x90;
fprintf(DEBUG,"%X %X %X\n\r",Pkt0.type,Pkt0.data[0],Pkt0.data[1]);
fprintf(DEBUG,"%X %X %X\n\r",Pkt1.type,Pkt1.data[0],Pkt1.data[1]);
fprintf(DEBUG,"----------\n\r");
fprintf(DEBUG,"%X \n\r",p_pkt[0]->type);
fprintf(DEBUG,"%X \n\r",p_pkt[0]->data[0]);
fprintf(DEBUG,"%X \n\r",p_pkt[0]->data[1]);
fprintf(DEBUG,"%X \n\r",p_pkt[1]->type);
fprintf(DEBUG,"%X \n\r",p_pkt[1]->data[0]);
fprintf(DEBUG,"%X \n\r",p_pkt[1]->data[1]);
while(1){}
Mark
Posted: Thu Nov 11, 2004 1:11 pm |
#device *=16
#case
#ZERO_RAM
#define VER_MAJOR 1
#use rs232(baud=57600,xmit=PIN_A2, INVERT, stream=DEBUG)
struct pkt
BYTE type;
BYTE data[25];
struct pkt* p_pkt[4];
#define TXSIZE 32
#define RXSIZE 16
set_tris_a(0xFF);
set_tris_b(0xFF);
set_tris_c(0xFF);
set_tris_d(0xFF);
set_tris_e(0xFF);
p_pkt[0]=&Pkt0;
p_pkt[1]=&Pkt1;
p_pkt[2]=&Pkt2;
p_pkt[3]=&Pkt3;
Pkt0.type = 0x10;
Pkt0.data[0]=0x20;
Pkt0.data[1]=0x30;
Pkt1.type = 0x70;
Pkt1.data[0]=0x80;
Pkt1.data[1]=0x90;
fprintf(DEBUG,"%X \n\r",(p_pkt[0])->type);
fprintf(DEBUG,"%X \n\r",(p_pkt[0])->data[0]);
fprintf(DEBUG,"%X \n\r",(p_pkt[0])->data[1]);
fprintf(DEBUG,"%X \n\r",(p_pkt[1])->type);
fprintf(DEBUG,"%X \n\r",(p_pkt[1])->data[0]);
fprintf(DEBUG,"%X \n\r",(p_pkt[1])->data[1]);
while(1){}
treitmey
Posted: Thu Nov 11, 2004 1:30 pm |
THANKS, THANKS,THANKS, THANKS,THANKS, THANKS!
order of evaluation, I get it...
never saw that comming.
Mark
Posted: Thu Nov 11, 2004 2:37 pm |
| Welcome, welcome, welcome. |
treitmey
Posted: Thu Nov 11, 2004 3:59 pm |
Perhaps someone can help me on this also. Why won't this work. : (
#device *=16
#case
#ZERO_RAM
#define VER_MAJOR 1
struct pkt
BYTE type;
BYTE data[25];
struct pkt * p_pkt[4];
//4 structs and an array of 4 pointers to the stucts
int8 i,n;
set_tris_a(0xFF);
set_tris_b(0xFF);
set_tris_c(0xFF);
set_tris_d(0xFF);
set_tris_e(0xFF);
p_pkt[0]=&Pkt0;
p_pkt[1]=&Pkt1;
p_pkt[2]=&Pkt2;
p_pkt[3]=&Pkt3;
Pkt0.data[1]=0x1;
Pkt1.data[1]=0x2;
Pkt2.data[1]=0x3;
Pkt3.data[1]=0x4;
fprintf(DEBUG,"%X %X %X %X\n\r",Pkt0.data[1],Pkt1.data[1],Pkt2.data[1],Pkt3.data[1]);
for (i=0;i<4;i++)
fprintf(DEBUG,"%X \n\r",(p_pkt[i])->data[1]);
while(1){}
treitmey
Posted: Thu Nov 11, 2004 5:27 pm |
| Can I simply not have 4 structs and a 4 elliment array of pointers to the struct? |
Mark
Posted: Thu Nov 11, 2004 8:22 pm |
Just a stinky compiler
for (i=0;i<4;i++)
fprintf(DEBUG,"%X \n\r", ((struct pkt*)p_pkt[i])->data[1]);
treitmey
Posted: Fri Nov 12, 2004 8:16 am |
So if i understand.
You typecast p_pkt to be of type pointer to struc pkt.
and then you wraped the part in front of the structure pointer operator '->'
Got it.
Thanks |
Mark
Posted: Fri Nov 12, 2004 8:38 am |
You got it.  |
