simple macro problem
alexz
PostPosted: Fri Oct 15, 2004 10:03 am     Reply with quote
#define USBN_RST USBN_BUS = 5
USBN_RST; <---Error: A numeric expression must appear here
Alex
dvsoft
PostPosted: Fri Oct 15, 2004 10:37 am     Reply with quote
bonsoir
juste write
#define USBN_RST USBN_BUS 5
when you use USBN_RST USBN_BUS in expression the compiler replace by 5
Alain
Mark
PostPosted: Fri Oct 15, 2004 11:06 am     Reply with quote
Did you declare USBN_BUS?
alexz
PostPosted: Mon Oct 18, 2004 4:00 am     Reply with quote
#define USBN_BUS PORTC;
Alex
Mark
PostPosted: Mon Oct 18, 2004 6:40 am     Reply with quote
Okay, did you declare PORTC?
CCS PCM C Compiler, Version 3.206, 22485               18-Oct-04 08:40
               Filename: test.LST
               ROM used: 17 words (0%)
                         Largest free fragment is 2048
               RAM used: 5 (3%) at main() level
                         5 (3%) worst case
               Stack:    0 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
....................  #include <16F877.H>
....................  //////// Standard Header file for the PIC16F877 device ////////////////
.................... #device PIC16F877
.................... #list
.................... #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
.................... #use delay(clock = 4000000)
.................... #byte PORTC = 0x07
.................... #define USBN_BUS PORTC
.................... #define USBN_RST USBN_BUS = 5
.................... void main()
0004:  CLRF   04
0005:  MOVLW  1F
0006:  ANDWF  03,F
0007:  BSF    03.5
0008:  BSF    1F.0
0009:  BSF    1F.1
000A:  BSF    1F.2
000B:  BCF    1F.3
.................... USBN_RST;
000C:  MOVLW  05
000D:  BCF    03.5
000E:  MOVWF  07
.................... while(TRUE)
000F:  GOTO   00F
0010:  SLEEP
Configuration Fuses:
   Word  1: 3F71   XT NOWDT PUT NOPROTECT BROWNOUT NOLVP NOCPD NOWRT NODEBUG
alexz
PostPosted: Mon Oct 18, 2004 6:42 am     Reply with quote
Yes, it is declared in the header file, I ve checked that
Alex
Mark
PostPosted: Mon Oct 18, 2004 6:46 am     Reply with quote
Well as everyone can clearly see, it works per my sample posted so you must be giving out misinformation. post a small simple but complete program that demonstrates the problem and maybe we can tell you what is wrong.
alexz
PostPosted: Mon Oct 18, 2004 6:59 am     Reply with quote
It is working now,
that is the way I ve eventually done it:
#include "SFR.h"
#define USBN_MCNTRL_ADDR 0x05
#define NUMBER 3
#define USBN_RST PORTC = N_MCNTRL_ADDR;\
bit_set(PORTC,NUMBER)
USBN_RST;
Thank you very much for your help !
Alex
