alexz
| simple macro problem |
Posted: Fri Oct 15, 2004 10:03 am |
#define USBN_RST USBN_BUS = 5
USBN_RST; <---Error: A numeric expression must appear here
} _________________ Alex |
dvsoft
Posted: Fri Oct 15, 2004 10:37 am |
bonsoir
juste write
#define USBN_RST USBN_BUS 5
when you use USBN_RST USBN_BUS in expression the compiler replace by 5
Alain |
Mark
Posted: Fri Oct 15, 2004 11:06 am |
| Did you declare USBN_BUS? |
alexz
Posted: Mon Oct 18, 2004 4:00 am |
| Mark wrote: | | Did you declare USBN_BUS? |
#define USBN_BUS PORTC; _________________ Alex |
Mark
Posted: Mon Oct 18, 2004 6:40 am |
Okay, did you declare PORTC?
| Code: | CCS PCM C Compiler, Version 3.206, 22485 18-Oct-04 08:40
Filename: test.LST
ROM used: 17 words (0%)
Largest free fragment is 2048
RAM used: 5 (3%) at main() level
5 (3%) worst case
Stack: 0 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
.................... #include <16F877.H>
.................... //////// Standard Header file for the PIC16F877 device ////////////////
.................... #device PIC16F877
.................... #list
.................... #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
.................... #use delay(clock = 4000000)
.................... #byte PORTC = 0x07
.................... #define USBN_BUS PORTC
.................... #define USBN_RST USBN_BUS = 5
0004: CLRF 04
0005: MOVLW 1F
0006: ANDWF 03,F
0007: BSF 03.5
0008: BSF 1F.0
0009: BSF 1F.1
000A: BSF 1F.2
000B: BCF 1F.3
.................... USBN_RST;
000C: MOVLW 05
000D: BCF 03.5
000E: MOVWF 07
.................... while(TRUE)
000F: GOTO 00F
0010: SLEEP
Configuration Fuses:
Word 1: 3F71 XT NOWDT PUT NOPROTECT BROWNOUT NOLVP NOCPD NOWRT NODEBUG
alexz
Posted: Mon Oct 18, 2004 6:42 am |
Yes, it is declared in the header file, I ve checked that _________________ Alex |
Mark
Posted: Mon Oct 18, 2004 6:46 am |
| Well as everyone can clearly see, it works per my sample posted so you must be giving out misinformation. post a small simple but complete program that demonstrates the problem and maybe we can tell you what is wrong. |
alexz
Posted: Mon Oct 18, 2004 6:59 am |
It is working now,
that is the way I ve eventually done it:
#include "SFR.h"
#define USBN_MCNTRL_ADDR 0x05
#define NUMBER 3
#define USBN_RST PORTC = N_MCNTRL_ADDR;\
bit_set(PORTC,NUMBER)
USBN_RST;
Thank you very much for your help ! _________________ Alex |
