Is it require to write signed for negative float..??
How negative float can be declared..??
What is its range when we declare it as signed float..??
Can we write signed float same way as normal float in the EEPROM..??
Or we need to do something extra for signed negative float number..??
Regards
Prashant
bdavis
Joined: 31 May 2004 Posts: 86 Location: Colorado Springs, CO
Posted: Tue Sep 21, 2004 10:37 pm
Just use float. It is possible to do a signed and unsigned float, but you would need to make your own routines and it would be a lot of work...
Currently there is IEEE type and a Microchip type that is commonly used in PIC's - both include pos/neg numbers for type float (without signed prefix in declaration). Write some test programs and you will learn lots more
