runtime
Can I use a 20Mhz Osc with a PIC18F252? |
Posted: Thu Aug 19, 2004 10:31 am |
Hello all,
I was using a 20Mhz ceramic osc (with built in caps) wit all my PIC16F876's, I'm switching to PIC18F252, can I use the same osc? how do I configure the fuses with this osc?
Thank you in advance
Peter |
mvaraujo
Posted: Thu Aug 19, 2004 11:04 am |
I particulary use 20MHz Xtal with the PIC18F252 but It's ok to use the resonator. |
valemike Guest
Posted: Thu Aug 19, 2004 11:39 am |
I've used a 4mhz resonator and a 20mhz xtal on the 18fx42 chips, and used #fuses HS,... on both. |
Mark
Posted: Thu Aug 19, 2004 11:56 am |
Use XT for 4MHz
Use HS for 20MHz |
runtime
Posted: Thu Aug 19, 2004 12:09 pm |
Thank you all for your help... |
