Can I use a 20Mhz Osc with a PIC18F252?
runtime
PostPosted: Thu Aug 19, 2004 10:31 am     Reply with quote
Hello all,
I was using a 20Mhz ceramic osc (with built in caps) wit all my PIC16F876's, I'm switching to PIC18F252, can I use the same osc? how do I configure the fuses with this osc?
Thank you in advance
Peter
mvaraujo
PostPosted: Thu Aug 19, 2004 11:04 am     Reply with quote
I particulary use 20MHz Xtal with the PIC18F252 but It's ok to use the resonator.
valemike
PostPosted: Thu Aug 19, 2004 11:39 am     Reply with quote
I've used a 4mhz resonator and a 20mhz xtal on the 18fx42 chips, and used #fuses HS,... on both.
Mark
PostPosted: Thu Aug 19, 2004 11:56 am     Reply with quote
Use XT for 4MHz
Use HS for 20MHz
runtime
PostPosted: Thu Aug 19, 2004 12:09 pm     Reply with quote
Thank you all for your help...
