Out of rom!
TheGaut
Out of rom!
PostPosted: Mon Mar 08, 2004 2:34 pm     Reply with quote
When i compile i get this error:
out of ROM, A segment or the program is too large.
main
Seg 0800-0FFF,0748 left,need 07FE
Help me please!!!
Thank you!
Kasper
PostPosted: Mon Mar 08, 2004 2:43 pm     Reply with quote
one of your functions is too large. Try splitting it up.
TheGaut
hmmm
PostPosted: Mon Mar 08, 2004 3:09 pm     Reply with quote
The function is not really big.
Kasper
PostPosted: Mon Mar 08, 2004 3:46 pm     Reply with quote
post the code so we can see if we can see anything then. Hard to tell without seeing it.
Also post your compiler version just in case.
Re: hmmm
PostPosted: Mon Mar 08, 2004 3:55 pm     Reply with quote
You may be suprised.
You can (for instance), write hugely long functions that result in quite small code (lots of simple input/output instructions), or conversely, write a 'one liner', that uses a huge amount of code space.
Printf statements are bulky, as are floating point arithmetic.
rwyoung
PostPosted: Mon Mar 08, 2004 6:38 pm     Reply with quote
The compiler likes to in-line function calls and that can make for lots of ROM use. Generally if the called function is only used in that one place then it will get in-line'd
I think there is a # directive that can be used to prevent automatic in-lining of code.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
mpfj
PostPosted: Tue Mar 09, 2004 3:24 am     Reply with quote
Look up #separate and #inline in the CCS manual
Darren Rook
PostPosted: Tue Mar 09, 2004 8:53 am     Reply with quote
If you call a function once the compiler will inline it. But if you call a function once and you're running out of space in that page then it will realize this and make it separate automatically.
