TheGaut Guest
Out of rom! |
Posted: Mon Mar 08, 2004 2:34 pm |
When i compile i get this error:
out of ROM, A segment or the program is too large.
main
Seg 0800-0FFF,0748 left,need 07FE
Help me please!!!
Thank you! |
Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Posted: Mon Mar 08, 2004 2:43 pm |
one of your functions is too large. Try splitting it up. |
TheGaut Guest
hmmm |
Posted: Mon Mar 08, 2004 3:09 pm |
The function is not really big. |
Kasper
Posted: Mon Mar 08, 2004 3:46 pm |
post the code so we can see if we can see anything then. Hard to tell without seeing it.
Also post your compiler version just in case. |
Re: hmmm |
Posted: Mon Mar 08, 2004 3:55 pm |
TheGaut wrote: | The function is not really big. |
You may be suprised.
You can (for instance), write hugely long functions that result in quite small code (lots of simple input/output instructions), or conversely, write a 'one liner', that uses a huge amount of code space.
Printf statements are bulky, as are floating point arithmetic.
rwyoung
Posted: Mon Mar 08, 2004 6:38 pm |
The compiler likes to in-line function calls and that can make for lots of ROM use. Generally if the called function is only used in that one place then it will get in-line'd
I think there is a # directive that can be used to prevent automatic in-lining of code. _________________ Rob Young
mpfj
Posted: Tue Mar 09, 2004 3:24 am |
Look up #separate and #inline in the CCS manual |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Tue Mar 09, 2004 8:53 am |
rwyoung wrote: | The compiler likes to in-line function calls and that can make for lots of ROM use. Generally if the called function is only used in that one place then it will get in-line'd
I think there is a # directive that can be used to prevent automatic in-lining of code. |
If you call a function once the compiler will inline it. But if you call a function once and you're running out of space in that page then it will realize this and make it separate automatically. |
