Keypad Implementation using A/D
rrb011270
PostPosted: Thu Feb 05, 2004 9:53 pm     Reply with quote
Mabuhay,
Anyone from the community who have done keypad implementation on a PIC using Analog-to-digital conversion?
Any info, materials and/or a sample snippet ...
Thank u.
kypec
simple implementation
PostPosted: Fri Feb 06, 2004 4:13 am     Reply with quote
if you want I will send you an Excel sheet which I used
for calculation of resistor values in ladder configuration.
The values were originally calculated for PIC with internal
comparator module but it can be also used for PIC with
A/D converter module of course.
All you need to do is just to type in your voltages, number of scanned keys and then obviously write some C functions for measuring
the analog input (Vx) and evaluating obtained value.
good luck with your project,
kypec
mechwu_2.0
Re: Keypad Implementation using A/D
PostPosted: Fri Feb 06, 2004 6:20 am     Reply with quote
I calculated as below for 3x4 and 4x4 keypad but never tested.
Let us know if it really works.
best wishes.
Ref. see Tip #7 of this AP notes.
http://www.microchip.com/1010/pline/picmicro/category/embctrl/8kbytes/devices/12f675/9827/index.htm
 +5V --------------------
     10k      6.7k     3.3k
      1        2        3  -40k-|
      4        5        6  -30k-|
      7        8        9  -20k-|
      *        0        #  -10k-|---> To Analog Port
                               50k
                               GND
key:   1     2     3     4     5     6     7     8     9     *     0     #
A/D:  128   132   137   142   147   153   159   166   174   182   191   201
         130   134   139   144   150   156   163   170   178   187   196
if       (y<120)  key = '?'
else if  (y<130)  key = '1'
else if  (y<134)  key = '2'
else              key = '#'
 +5V -----------------------------
     12k       9k       6k       3k
      1        2        3        A  -37k-|
      4        5        6        B  -25k-|
      7        8        9        C  -13k-|
      *        0        #        D  - 1k-|---> To Analog Port
                                        47k
                                        GND
key:  1   2   3   A   4   5   6   B   7   8   9   C   *   0   #   D
A/D: 125 129 133 138 143 148 154 160 166 174 182 190 200 210 222 235
       127 131 135 140 145 151 157 163 170 178 186 195 205 216 228
else if  (y<127)  key = '1'
else if  (y<131)  key = '2'
else              key = 'D'
mechwu_2.0
Something I forgot ...
PostPosted: Fri Feb 06, 2004 12:11 pm     Reply with quote
1. The contact resistance of keypad is not considered in my design.
2. The contact resistance of keypad might get rusted after years ...
rrb011270
Re: simple implementation
PostPosted: Sat Feb 07, 2004 7:19 am     Reply with quote
kypec wrote:
kypec
Hello Kypec, I'll love if u can send me the Excel sheet for my reference in the calculation of the resistor... my email address is rrb011270@yahoo.com..
If u have some other points please share it coz I'll love to implement this keypad thing using PIC A/D. A snippet will be a good start for my projects...
I'll wired the switches and the reset of the circuits on monday... I'll keep u posted..
once again thnx for the info/tips
rrb011270
PostPosted: Sat Feb 07, 2004 7:43 am     Reply with quote
best wishes.
     10k      6.7k     3.3k
      1        2        3  -40k-|
      4        5        6  -30k-|
      7        8        9  -20k-|
                               50k
                               GND
else              key = '#'
     12k       9k       6k       3k
      1        2        3        A  -37k-|
      4        5        6        B  -25k-|
      7        8        9        C  -13k-|
                                        47k
                                        GND
else              key = 'D'
Hello mechwu_2.0,
How many bits u use for the A/D in order to get the values of the resistors.
I plan to use it on a 10-bit A/D
Thnx
mechwu_2.0
To: rrb011270
PostPosted: Sat Feb 07, 2004 8:12 pm     Reply with quote
1. For 10-bit A/D, simply multiply my numbers by 4.
2. The contact resistance of my keypad is 20 ~ 100 ohm depends on how hard it is pressed, measureded with a multimeter. check it out with your keypad.
Best wishes
rrb-pic
Re: To: rrb011270
PostPosted: Sat Feb 07, 2004 8:18 pm     Reply with quote
Best wishes
1. For 10-bit A/D, simply multiply my numbers by 4. ---> what u mean by this? do u mean the A/D value will be multiplied by 4.?
this for clarification....
thnx
rrb011270.
Re: To: rrb011270
PostPosted: Sat Feb 07, 2004 8:19 pm     Reply with quote
Best wishes
thnx
PostPosted: Sat Feb 07, 2004 9:48 pm     Reply with quote
else key = '#'
For 4x3 keypad with 10 bit-A/D value 0 ~ 1023, it should be:
if (y<480) key = '?'
else if (y<520) key = '1'
else if (y<536) key = '2'
else if (y<556) key = '2'
else key = '#'
You can recompute the numbers based on the resistor network for better performance. for example, key '1' gives roughly 1023*(50k)/(10k+40k+50k) = 511.5, key '2' gives roughly 1023*(50k)/(6.7k+40k+50k)=529, so, the decision point should better be (511.5+529)/2 = 520, well, still the same as 130 x 4 in this case, so,
should work
Best wishes
PostPosted: Sun Feb 08, 2004 5:17 pm     Reply with quote
Can this method of keypad implementation using a one channel A/D say, AN0 incorporates with #int_ad be possible?
need your comments....
thanx
PostPosted: Sun Feb 08, 2004 11:20 pm     Reply with quote
best wishes.
     10k      6.7k     3.3k
      1        2        3  -40k-|
      4        5        6  -30k-|
      7        8        9  -20k-|
                               50k
                               GND
else              key = '#'
     12k       9k       6k       3k
      1        2        3        A  -37k-|
      4        5        6        B  -25k-|
      7        8        9        C  -13k-|
                                        47k
                                        GND
else              key = 'D'
How can we change the resistor value such that the gap between buttons is large enough to prevent mistrigger? I need your comments please...
Thanx
mechwu_2.0
PostPosted: Mon Feb 09, 2004 5:45 am     Reply with quote
I did my design by trial and error to equalize the gap between buttons. Considering 8 bit A/D with 5 V for 0 ~ 255, each step is 5000 mV / 255 ~ 20 mV, and my design gives a minimal gap of 4, which means roughly 80 mV, so, it should work under a noise less than 10 mV, which shall not be difficult. Anyway, I never tested, so, that'a all I can say.
Good luck
