rrb011270
Keypad Implementation using A/D |
Posted: Thu Feb 05, 2004 9:53 pm |
Mabuhay,
Anyone from the community who have done keypad implementation on a PIC using Analog-to-digital conversion?
Any info, materials and/or a sample snippet ...
Thank u. |
kypec
simple implementation |
Posted: Fri Feb 06, 2004 4:13 am |
if you want I will send you an Excel sheet which I used
for calculation of resistor values in ladder configuration.
The values were originally calculated for PIC with internal
comparator module but it can be also used for PIC with
A/D converter module of course.
All you need to do is just to type in your voltages, number of scanned keys and then obviously write some C functions for measuring
the analog input (Vx) and evaluating obtained value.
good luck with your project,
kypec |
mechwu_2.0 Guest
Re: Keypad Implementation using A/D |
Posted: Fri Feb 06, 2004 6:20 am |
I calculated as below for 3x4 and 4x4 keypad but never tested.
Let us know if it really works.
best wishes.
Ref. see Tip #7 of this AP notes.
http://www.microchip.com/1010/pline/picmicro/category/embctrl/8kbytes/devices/12f675/9827/index.htm
+5V --------------------
10k 6.7k 3.3k
1 2 3 -40k-|
4 5 6 -30k-|
7 8 9 -20k-|
* 0 # -10k-|---> To Analog Port
50k
GND
key: 1 2 3 4 5 6 7 8 9 * 0 #
A/D: 128 132 137 142 147 153 159 166 174 182 191 201
130 134 139 144 150 156 163 170 178 187 196
if (y<120) key = '?'
else if (y<130) key = '1'
else if (y<134) key = '2'
else key = '#'
+5V -----------------------------
12k 9k 6k 3k
1 2 3 A -37k-|
4 5 6 B -25k-|
7 8 9 C -13k-|
* 0 # D - 1k-|---> To Analog Port
47k
GND
key: 1 2 3 A 4 5 6 B 7 8 9 C * 0 # D
A/D: 125 129 133 138 143 148 154 160 166 174 182 190 200 210 222 235
127 131 135 140 145 151 157 163 170 178 186 195 205 216 228
else if (y<127) key = '1'
else if (y<131) key = '2'
else key = 'D'
mechwu_2.0 Guest
Something I forgot ... |
Posted: Fri Feb 06, 2004 12:11 pm |
1. The contact resistance of keypad is not considered in my design.
2. The contact resistance of keypad might get rusted after years ... |
rrb011270
Re: simple implementation |
Posted: Sat Feb 07, 2004 7:19 am |
kypec wrote: | Hi,
kypec |
Hello Kypec, I'll love if u can send me the Excel sheet for my reference in the calculation of the resistor... my email address is rrb011270@yahoo.com..
If u have some other points please share it coz I'll love to implement this keypad thing using PIC A/D. A snippet will be a good start for my projects...
I'll wired the switches and the reset of the circuits on monday... I'll keep u posted..
once again thnx for the info/tips |
rrb011270
Posted: Sat Feb 07, 2004 7:43 am |
mechwu_2.0 wrote: | I calculated as below for 3x4 and 4x4 keypad but never tested.
best wishes.
10k 6.7k 3.3k
1 2 3 -40k-|
4 5 6 -30k-|
7 8 9 -20k-|
50k
GND
else key = '#'
12k 9k 6k 3k
1 2 3 A -37k-|
4 5 6 B -25k-|
7 8 9 C -13k-|
47k
GND
else key = 'D'
Hello mechwu_2.0,
How many bits u use for the A/D in order to get the values of the resistors.
I plan to use it on a 10-bit A/D
Thnx |
mechwu_2.0 Guest
To: rrb011270 |
Posted: Sat Feb 07, 2004 8:12 pm |
1. For 10-bit A/D, simply multiply my numbers by 4.
2. The contact resistance of my keypad is 20 ~ 100 ohm depends on how hard it is pressed, measureded with a multimeter. check it out with your keypad.
Best wishes |
rrb-pic Guest
Re: To: rrb011270 |
Posted: Sat Feb 07, 2004 8:18 pm |
mechwu_2.0 wrote: | 1. For 10-bit A/D, simply multiply my numbers by 4.
Best wishes |
1. For 10-bit A/D, simply multiply my numbers by 4. ---> what u mean by this? do u mean the A/D value will be multiplied by 4.?
this for clarification....
thnx |
rrb011270. Guest
Re: To: rrb011270 |
Posted: Sat Feb 07, 2004 8:19 pm |
Best wishes |
thnx |
Posted: Sat Feb 07, 2004 9:48 pm |
else key = '#'
For 4x3 keypad with 10 bit-A/D value 0 ~ 1023, it should be:
if (y<480) key = '?'
else if (y<520) key = '1'
else if (y<536) key = '2'
else if (y<556) key = '2'
else key = '#'
You can recompute the numbers based on the resistor network for better performance. for example, key '1' gives roughly 1023*(50k)/(10k+40k+50k) = 511.5, key '2' gives roughly 1023*(50k)/(6.7k+40k+50k)=529, so, the decision point should better be (511.5+529)/2 = 520, well, still the same as 130 x 4 in this case, so,
should work
Best wishes |
Posted: Sun Feb 08, 2004 5:17 pm |
Can this method of keypad implementation using a one channel A/D say, AN0 incorporates with #int_ad be possible?
need your comments....
thanx |
Posted: Sun Feb 08, 2004 11:20 pm |
best wishes.
10k 6.7k 3.3k
1 2 3 -40k-|
4 5 6 -30k-|
7 8 9 -20k-|
50k
GND
else key = '#'
12k 9k 6k 3k
1 2 3 A -37k-|
4 5 6 B -25k-|
7 8 9 C -13k-|
47k
GND
else key = 'D'
How can we change the resistor value such that the gap between buttons is large enough to prevent mistrigger? I need your comments please...
Thanx |
mechwu_2.0 Guest
Posted: Mon Feb 09, 2004 5:45 am |
I did my design by trial and error to equalize the gap between buttons. Considering 8 bit A/D with 5 V for 0 ~ 255, each step is 5000 mV / 255 ~ 20 mV, and my design gives a minimal gap of 4, which means roughly 80 mV, so, it should work under a noise less than 10 mV, which shall not be difficult. Anyway, I never tested, so, that'a all I can say.
Good luck |
