rolf_edmundo_guse
Help for GLCD 128X64 driver ST7920 |
Posted: Wed Apr 17, 2019 6:43 am |
I'm new to this forum and I apologize if you're posting something wrong.
I'm struggling to find library glcd 128x64 drive st7920 someone would use pic18f87k22 |
Posted: Wed Apr 17, 2019 6:52 am |
Look in the code library:
<http://www.ccsinfo.com/forum/viewtopic.php?t=49505&highlight=st7920> |
rolf_edmundo_guse
Posted: Wed Apr 17, 2019 7:05 am |
Ttelmah wrote: | Look in the code library:
Thanks for the answer, i will be implementing and performing test soon post results. |
rolf_edmundo_guse
Posted: Fri Apr 19, 2019 1:59 pm |
I did the tests in text mode works, in graphical mode I was not able to perform. Does anyone have an example of using graphic mode? |
rolf_edmundo_guse
Re: Help for GLCD 128X64 driver ST7920 |
Posted: Fri Apr 19, 2019 8:28 pm |
rolf_edmundo_guse wrote: | I'm new to this forum and I apologize if you're posting something wrong.
After reading the datasheet several and several times discovers that the error for use of the graphical mode on the lcd 128x64 drive st7920.
void glcd_update ()
int8 v, h;
if (gdram.refresh)
for (v = 0; v <YVAL; v ++) // 64
if (v <32) // first part
glcd_instruction (0x80 | v); // Set Vertical Address.
glcd_instruction (0x80); // Set Horizontal Address.
else // second lcd stop
glcd_instruction (0x80 | (v - 32)); // Set Vertical Address.
glcd_instruction (0x88); // Set Horizontal Address.
for (h = 0; h <XVAL; h ++) // 8
glcd_data (gdram.pix [v] [h] .nbyte [1]); // Write High Byte.
glcd_data (gdram.pix [v] [h] .nbyte [0]); // Write Low Byte.
gdram.refresh = FALSE;
Joined: 01 Jul 2010 Posts: 9164 Location: Greensville,Ontario
Posted: Sat Apr 27, 2019 8:16 am |
Nice ! You should actually post your 'driver code' in the 'Code Library' forum as well. It's a great source of working code!!
Jay
Driver code posts moved to Code Library forum:
http://www.ccsinfo.com/forum/viewforum.php?f=2
-Forum Moderator
rolf_edmundo_guse
Posted: Sat Apr 27, 2019 2:16 pm |
temtronic wrote: | Nice ! You should actually post your 'driver code' in the 'Code Library' forum as well. It's a great source of working code!!
Jay
-Forum Moderator
OK |
