Help for GLCD 128X64 driver ST7920
rolf_edmundo_guse
PostPosted: Wed Apr 17, 2019 6:43 am     Reply with quote
I'm new to this forum and I apologize if you're posting something wrong.
I'm struggling to find library glcd 128x64 drive st7920 someone would use pic18f87k22
PostPosted: Wed Apr 17, 2019 6:52 am     Reply with quote
Look in the code library:
<http://www.ccsinfo.com/forum/viewtopic.php?t=49505&highlight=st7920>
rolf_edmundo_guse
PostPosted: Wed Apr 17, 2019 7:05 am     Reply with quote
Thanks for the answer, i will be implementing and performing test soon post results.
rolf_edmundo_guse
PostPosted: Fri Apr 19, 2019 1:59 pm     Reply with quote
I did the tests in text mode works, in graphical mode I was not able to perform. Does anyone have an example of using graphic mode?
rolf_edmundo_guse
Re: Help for GLCD 128X64 driver ST7920
PostPosted: Fri Apr 19, 2019 8:28 pm     Reply with quote
After reading the datasheet several and several times discovers that the error for use of the graphical mode on the lcd 128x64 drive st7920.
void glcd_update ()
   int8 v, h;
   if (gdram.refresh)
     for (v = 0; v <YVAL; v ++) // 64
       if (v <32) // first part
          glcd_instruction (0x80 | v); // Set Vertical Address.
          glcd_instruction (0x80); // Set Horizontal Address.
       else // second lcd stop
          glcd_instruction (0x80 | (v - 32)); // Set Vertical Address.
          glcd_instruction (0x88); // Set Horizontal Address.
       for (h = 0; h <XVAL; h ++) // 8
         glcd_data (gdram.pix [v] [h] .nbyte [1]); // Write High Byte.
         glcd_data (gdram.pix [v] [h] .nbyte [0]); // Write Low Byte.
     gdram.refresh = FALSE;
PostPosted: Sat Apr 27, 2019 8:16 am     Reply with quote
Nice ! You should actually post your 'driver code' in the 'Code Library' forum as well. It's a great source of working code!!
Jay
Driver code posts moved to Code Library forum:
http://www.ccsinfo.com/forum/viewforum.php?f=2
-Forum Moderator
rolf_edmundo_guse
PostPosted: Sat Apr 27, 2019 2:16 pm     Reply with quote
Jay
-Forum Moderator
OK
