set functions at a predefined location
Eldert Besseling
PostPosted: Tue Jan 13, 2004 5:28 am     Reply with quote
What is the best way to set a function in a pre defined location in ROM
i use #org statement but i have not a good result.
My intention is:
# set location in ROM
void function( void )
Can anyone help me?
Regards Eldert
Mark
PostPosted: Tue Jan 13, 2004 7:14 am     Reply with quote
The answer:
#org
Post an example and someone might be able to tell you what the problem is.
PostPosted: Tue Jan 13, 2004 8:22 am     Reply with quote
I try the following code
#separate
void Communications(void);
#org 0x100, 0x150
my compiler generate an out of ROM error
Darren Rook
PostPosted: Tue Jan 13, 2004 8:52 am     Reply with quote
Probably because Communications() is larger than 0x50 bytes.
Also, if you're using an interrupt the compiler may be trying to use those ROM locations.
Also, you don't have to use #separate with #org. #separate is implied when using #org.
Eldert Besseling
PostPosted: Tue Jan 13, 2004 9:04 am     Reply with quote
Oke thanks all for your help it works
RGS Eldert
