Eldert Besseling
set functions at a predefined location |
Posted: Tue Jan 13, 2004 5:28 am |
What is the best way to set a function in a pre defined location in ROM
i use #org statement but i have not a good result.
My intention is:
# set location in ROM
void function( void )
Can anyone help me?
Regards Eldert |
Mark
Posted: Tue Jan 13, 2004 7:14 am |
The answer:
#org
Post an example and someone might be able to tell you what the problem is. |
Posted: Tue Jan 13, 2004 8:22 am |
I try the following code
#separate
void Communications(void);
#org 0x100, 0x150
my compiler generate an out of ROM error |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Tue Jan 13, 2004 8:52 am |
Anonymous wrote: |
Probably because Communications() is larger than 0x50 bytes.
Also, if you're using an interrupt the compiler may be trying to use those ROM locations.
Also, you don't have to use #separate with #org. #separate is implied when using #org. |
Eldert Besseling
Posted: Tue Jan 13, 2004 9:04 am |
Oke thanks all for your help it works
RGS Eldert |
