POPE19
Incorrect ADC values for PIC16F1939 |
Posted: Thu Sep 07, 2017 7:43 am |
I am using pic16f1939 for adxl335. The adc values read by pic is incorrect with 3.3 v reference.
It should read:
x - 1.611v (499)
y - 1.578v (489)
z - 1.985v (615)
However on serial monitor it is displayed as:
x = 126 y = 126 z = 126
#include <16F1939.h>
#fuses HS ,NOVCAP, MCLR, NOWDT, PUT, NOIESO, BROWNOUT, NOFCMEN,PLL_SW
#use delay(crystal=20MHz, clock=20MHz)
#define INTS_PER_SECOND 76 // (20000000/(4*256*256))
int int_count=INTS_PER_SECOND;
long seconds=0;
long x,y,z;
#INT_TIMER0 //This function is called
void clock_isr()
{ //every time the RTCC (timer0)
//overflows (255->0)
//For this program this is apx
//31 times per second.
if(--int_count==0)
seconds++;
void adc_cal()
SET_ADC_CHANNEL (0); // select AN0 channel
delay_us(30); // delay for sampling time Tad.
x = read_adc(); // read channel
printf("X = %LU \t ",x);
SET_ADC_CHANNEL (5); // select AN5 channel
delay_us(30);
y = read_adc();
printf("Y = %LU \t ",x);
SET_ADC_CHANNEL (12); // select AN12 channel
delay_us(30);
z= read_adc();
printf("Z = %LU \n \r ",x);
set_tris_a (0xC9); //set RA-0,3,6,7 as inputs
set_tris_b (0xC9); //set RB-0,3,6,7 as inputs
set_rtcc(0);
setup_timer_0(T0_INTERNAL | T0_DIV_256 | T0_8_BIT);
setup_vref (VREF_OFF | VREF_ADC_OFF|VREF_COMP_DAC_OFF|TEMPERATURE_INDICATOR_DISABLED);
setup_adc (ADC_CLOCK_DIV_32);
//select A0,E0,B0 as analog input & (Vref+ = 3.3v) as voltage reference
setup_adc_ports(sAN0 | sAN5 | sAN12,VSS_VREF);
setup_comparator (NC_NC_NC_NC);
enable_interrupts (INT_TIMER0);
while (TRUE)
if(seconds>1)
adc_cal();
seconds =0;
newguy
Re: INCORRECT ADC VALUES FOR PIC16F1939 |
Posted: Thu Sep 07, 2017 7:47 am |
Code: | setup_adc_ports(sAN0 | sAN5 | sAN12,VSS_VREF); |
This line is telling the processor that YOU are supplying an external positive voltage reference for the A/D into the PIC's VREF+ pin. Is that what you are doing? If you instead want to set up the A/D to use the PIC's positive supply as the positive reference, then this line needs to change. Open the PIC16F1939.h file and look for the A/D section for the proper constants to use in this function. |
alan
Joined: 12 Nov 2012 Posts: 357 Location: South Africa
Posted: Thu Sep 07, 2017 7:58 am |
Is this correct?
Code: | y = read_adc();
printf("Y = %LU \t ",x); |
Shouldn't x be y. Same hold for z.[/b] |
POPE19
Posted: Thu Sep 07, 2017 8:13 am |
Yes i am supplying the positive voltage 3.3volts on pin 5 (RA3). i don't want to use pic internal voltage reference.
Yes i changed the printf commands but still it displays wrong values:
x = 126 y=126 z = 156
void adc_cal()
delay_us(30);
y = read_adc();
printf("Y = %LU \t ",y);
delay_us(30);
z= read_adc();
printf("Z = %LU \n \r ",z);
Posted: Thu Sep 07, 2017 8:21 am |
Now it makes sense......
#device ADC-=10
Without this it is defaulting to returning the 8bit ADC value. |
POPE19
Posted: Thu Sep 07, 2017 9:08 am |
It works !! Thank you. |
