Incorrect ADC values for PIC16F1939
POPE19
PostPosted: Thu Sep 07, 2017 7:43 am     Reply with quote
I am using pic16f1939 for adxl335. The adc values read by pic is incorrect with 3.3 v reference.
It should read:
x - 1.611v (499)
y - 1.578v (489)
z - 1.985v (615)
However on serial monitor it is displayed as:
x = 126 y = 126 z = 126
#include <16F1939.h>
#fuses HS ,NOVCAP, MCLR, NOWDT, PUT, NOIESO, BROWNOUT, NOFCMEN,PLL_SW
#use delay(crystal=20MHz, clock=20MHz)
#define INTS_PER_SECOND     76      // (20000000/(4*256*256))
int int_count=INTS_PER_SECOND;
long seconds=0;
long x,y,z;
#INT_TIMER0          //This function is called
void clock_isr()
{                       //every time the RTCC (timer0)
                        //overflows (255->0)
                        //For this program this is apx
                        //31 times per second.
   if(--int_count==0)
      seconds++;
void adc_cal()
    SET_ADC_CHANNEL (0); // select AN0 channel
    delay_us(30);       // delay for sampling time Tad.
    x = read_adc();     // read channel
    printf("X = %LU \t ",x);
    SET_ADC_CHANNEL (5); // select AN5 channel
    delay_us(30);
    y = read_adc();
    printf("Y = %LU \t ",x);
    SET_ADC_CHANNEL (12); // select AN12 channel
    delay_us(30);
    z= read_adc();
    printf("Z = %LU \n \r ",x);
   set_tris_a (0xC9); //set RA-0,3,6,7 as inputs
   set_tris_b (0xC9); //set RB-0,3,6,7 as inputs
   set_rtcc(0);
   setup_timer_0(T0_INTERNAL | T0_DIV_256 | T0_8_BIT);
   setup_vref (VREF_OFF | VREF_ADC_OFF|VREF_COMP_DAC_OFF|TEMPERATURE_INDICATOR_DISABLED);
   setup_adc (ADC_CLOCK_DIV_32);
   //select A0,E0,B0 as analog input & (Vref+ = 3.3v) as voltage reference
   setup_adc_ports(sAN0 | sAN5 | sAN12,VSS_VREF);
   setup_comparator (NC_NC_NC_NC);
   enable_interrupts (INT_TIMER0);
   while (TRUE)
      if(seconds>1)
          adc_cal();
          seconds =0;
newguy
Re: INCORRECT ADC VALUES FOR PIC16F1939
PostPosted: Thu Sep 07, 2017 7:47 am     Reply with quote
This line is telling the processor that YOU are supplying an external positive voltage reference for the A/D into the PIC's VREF+ pin. Is that what you are doing? If you instead want to set up the A/D to use the PIC's positive supply as the positive reference, then this line needs to change. Open the PIC16F1939.h file and look for the A/D section for the proper constants to use in this function.
alan
PostPosted: Thu Sep 07, 2017 7:58 am     Reply with quote
Is this correct?
y = read_adc();
Shouldn't x be y. Same hold for z.[/b]
POPE19
PostPosted: Thu Sep 07, 2017 8:13 am     Reply with quote
Yes i am supplying the positive voltage 3.3volts on pin 5 (RA3). i don't want to use pic internal voltage reference.
Yes i changed the printf commands but still it displays wrong values:
x = 126 y=126 z = 156
void adc_cal()
    delay_us(30);
    y = read_adc();
    printf("Y = %LU \t ",y);
    delay_us(30);
    z= read_adc();
    printf("Z = %LU \n \r ",z);
PostPosted: Thu Sep 07, 2017 8:21 am     Reply with quote
Now it makes sense...... Smile
#device ADC-=10
Without this it is defaulting to returning the 8bit ADC value.
POPE19
PostPosted: Thu Sep 07, 2017 9:08 am     Reply with quote
It works !! Thank you.
