Niewbie Guest
MMC Endurance? |
Posted: Sun Jan 04, 2004 8:25 am |
What is the maximum write cycles for MMC, can't find anything on this as all I get is people advertising cards!
P.S. What IC technology is in the MMC if you know that I might be able to find the answer myself. |
Newbie Guest
More questions!! |
Posted: Sun Jan 04, 2004 9:04 am |
I'm still trying to find answeres on this, and thought of answer question, I think I have found the MMC has 300,000 write/erase cycles, CF about 1,000,000 but does that apply to the entire device or each byte?
In other words is I write 1 byte to address 0,1,2,3,4,5,6 etc in a CF and I get to address 1,000,0000 it will stop or if I write 1 byte to address 0 1,000,000 times then address 0 will fail?
Thanks |
johnh
Joined: 03 Jan 2004 Posts: 19 Location: UK - Brighton
Posted: Sun Jan 04, 2004 9:12 am |
Hi
Follow this link, i haven't read it all but there should be some answers in there.
http://www.mmca.org/tech/MMC-System-Summary-v3.31.pdf
Also try searching google for MultiMediaCard write cycles
I just tried it and it comes up with some info.
John _________________ There are 10 kinds of people who understand binary, those who do and those who don't |
steve_st23
Posted: Sun Jan 11, 2004 7:51 am |
follow this link for sd card and look at page 11 section 1.5.4 Endurance http://www.sandisk.com/pdf/oem/ProdManualSDCardv1.9.pdf
100000 write cycle for each sector typical (from 512 bytes to maximum capacity for each sector) |
