#int_tmr0 Help
ritchie
#int_tmr0 Help
PostPosted: Thu Dec 18, 2003 7:39 pm     Reply with quote
I'm planning to use the RTC of my PIC18F452 to tic every seconds at 20MHz clock.
I put instructions into my code as stated below:
#int_timer0
timer0_isr() {
   seconds++;            // This interrupt occurs every second
   ticxf = 1;                // set timer flag
   set_timer0(26473); // 26473.5 offset for 1.0s time in DIV_128
at my main routine I add this instructions:
setup_adc_ports(NO_ANALOGS);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_128);
enable_interrupts(int_timer0);
My question is... I am correct with my setup in using timer0 that tic every seconds.
Anybody in the community who can provide me with a basic math calculation if in case I change the clock from 20MHz to 6Mhz.
A generic model would help... thank u
Re: #int_tmr0 Help
PostPosted: Fri Dec 19, 2003 8:18 am     Reply with quote
ritchie wrote:
#int_timer0
timer0_isr() {
If you do a search in this forum for RTC you will find some excellent examples of much better solutions than what you plan to use.
