I'm planning to use the RTC of my PIC18F452 to tic every seconds at 20MHz clock.
I put instructions into my code as stated below:
#int_timer0
timer0_isr() {
seconds++; // This interrupt occurs every second
ticxf = 1; // set timer flag
set_timer0(26473); // 26473.5 offset for 1.0s time in DIV_128
My question is... I am correct with my setup in using timer0 that tic every seconds.
Anybody in the community who can provide me with a basic math calculation if in case I change the clock from 20MHz to 6Mhz.
A generic model would help... thank u
Re: #int_tmr0 Help
Posted: Fri Dec 19, 2003 8:18 am
ritchie wrote:
#int_timer0
timer0_isr() {
