aaronik19
TRIAC Flickering problem |
Posted: Tue Apr 05, 2016 3:34 am |
Dear All,
I am trying to make a new triac switch using an optocoupler and TRIAC. Please refer to the attached picture.
http://postimg.org/image/x3ok52vkd/
I am trying to interface the PIC micro to control the duration of the on and off. But first I am trying the power hardware before I move to the software and when I apply 5V to the optocoupler the lamp switch on 100% ... so far so good!
But when I remove the 5V, the lamp starts to flicker fast and when I measure the voltage from teh output of the TRIAC to neutral I found 163VAC. The lamp power is 50W and the TRIAC is 1A.
Can someone tell me what coulc be the problem. From my knowledge when you switch of the input of the optocoupler the lamp must switch off. right? Thanks for your help and support as always. |
Posted: Tue Apr 05, 2016 4:05 am |
Nothing to hold the TRIAC off. You need a resistor from the gate to the bottom, to prevent 'self commutating' (which is what you are seeing). It also depends on the power factor of your load. Though a simple resistive lamp ought to be pretty neutral, it is surprising how often either capacitance or inductance is present in the circuit (wound filament lamps often have quite noticeable inductance). Honestly I really would suggest doing the design another way. TRIACs are a really bad way of doing almost anything!. Individual SCR's are always better, and even better GTO SCR's or MOSFET's. 99.9% of the interference problems in domestic electronics are caused by TRIAC based circuits..... |
aaronik19
Posted: Tue Apr 05, 2016 7:10 am |
As a further comment to this, the two MOSFET's in series approach given slightly further down the thread, is the basis of many of the AC/DC SSR units being sold.
Going even more ingenious, you can use zero crossing on this, and can do the opposite of a TRIAC, turning 'on' at the zero point, then 'off' mid cycle. This is what is needed (or a GTO thyristor that can also be turned off like this), to control capacitive loads. |
asmboy
Posted: Tue Apr 05, 2016 7:30 am |
Quote: | to control capacitive loads. |
or you can skip the zero cross detector -- put an appropriate stiff TVS in parallel with the MOSFET and then PWM drive the gate at a base frequency more than 100 times the line frequency, and use a bridge with a PIV rating 50% higher than the mains peak-2-peak voltage
don't forget the L-C switch garbage suppressor though. People in the area of the modulator might like to listen to lowband AM radio ;-)) |
Posted: Tue Apr 05, 2016 7:45 am |
And it is amazing what a good transmission aerial your house wiring makes!.... ![Evil or Very Mad](images/smiles/icon_evil.gif) |
aaronik19
Posted: Wed Apr 06, 2016 1:58 am |
To continue discuss this topic..I want to ask you, is it possible to drive ac load with two mosfets in series driven by optocoupler? I searched on google and saw many forums which says that mosfets are for dc not ac. |
Posted: Wed Apr 06, 2016 2:45 am |
That's the point about the two MOSFET's in series.
Each MOSFET can only control current in one direction. However use two in series and you can switch current flowing each way.
As I said, this is the basis of some of the AC/DC SSR's.
If you look for a 'random turn on SSR', this has all the high voltage parts, and the isolation already built for you, and is a far safer way to go, than anything involving actual mains circuitry....
Have a look at this:
<http://www.crydom.com/en/tech/newsletters/solid%20statements%20-%20ssrs%20switching%20types.pdf>
and consider using a suitable SSR. |
aaronik19
Joined: 01 Jul 2010 Posts: 9177 Location: Greensville,Ontario
Posted: Wed Apr 06, 2016 12:57 pm |
hmm they bring the center tap out labelled 'DC' so you could use it on DC one would think....
There's bound to be a few apnotes about them. Nice to interface to PIC as it's optocoupled and PIC can direct drive it.
Jay |
Mike Walne
Posted: Wed Apr 06, 2016 2:45 pm |
What I've gleaned from the data sheet:-
The switching times are in the ms region.
So you can only think in terms of slow speed control.
PWM type operation (dimming) is probably out of the question.
The DC current rating is twice the AC one.
Presumably you take the DC out via the centre tap.
That way your only passing the current through one MOSFET.
Mike
They're not showing much detail on how the MOSFET is driven.
I'd guess it's a PV diode (or few), hence the speed, or lack of it. |
asmboy
Posted: Wed Apr 06, 2016 4:06 pm |
are your lamps filament or led ?
what POWER level :: Volts and AMPs please- when fully ON.
-do you have PRIOR experience with designing AC dimming circuits?
because the circuit discussion so far makes me nervous that answer number
3 is no ...... ![Sad](images/smiles/icon_sad.gif)
Posted: Wed Apr 06, 2016 4:12 pm |
Then there's the KISS way of PWM 'light'. Use a PIC, mosfet and '12 volt' LEDS. They are EASY to control, cheap and SAFE !!! Anything with 'mains' power HAS to be treated with the utmost of respect. If getting zapped doesn't kill you, whacking your head on the table across the room sure hurts. BTDT.
Jay |
gpsmikey
Posted: Wed Apr 06, 2016 6:42 pm |
temtronic wrote: | Then there's the KISS way of PWM 'light'. Use a PIC, mosfet and '12 volt' LEDS. They are EASY to control, cheap and SAFE !!! Anything with 'mains' power HAS to be treated with the utmost of respect. If getting zapped doesn't kill you, whacking your head on the table across the room sure hurts. BTDT.
Jay |
Yeah, I miss the old days of playing with the old tube radios with hundreds of volts wandering around in there. Those could certainly convince the unwary to take up management or accounting
mikey _________________ mikey
aaronik19
Posted: Thu Apr 07, 2016 8:28 am |
Hi all, continued to make some more experiments and i built the attached circuit using IRF740 Mosfets.
http://postimg.org/image/wwa7bebl3/
The circuit worked perfectly and when i replaced 1k resistor and used a pot to dim, the filament dims accordingly and perfectly. The only issue is that the mosfets become very warm.
I would like to test this circuit using dimmable led to see the result. |
