What dev. boards are you using for prototyping?
ELCouz
PostPosted: Sat Jan 24, 2015 4:46 pm     Reply with quote
I find this little gem using PIC24FJ128GA010 (with ICSP headers) with onboard CP2102 Serial to USB bridge.
http://www.ebay.com/itm/StarterKit-PIC24FJ128GA010-PIC24-MEGA-Development-board-/161025455438
This is the perfect form factor, not too big not too small! Price is right (33$) Can't find the same for dsPIC and PIC18.
I find the ChipKIT UNO32 and MAX32 to have the same layout but I can't use CCS Compiler with that! (PIC32 based)
Just wondering what are you using for dev?
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
jgschmidt
PostPosted: Mon Jan 26, 2015 3:57 pm     Reply with quote
I still use mostly solderless prototyping boards and DIP versions of the processor. For larger pin-count or SMD-only chips I get or make my own breakout boards that I can plug into the prototyping boards. That leaves me with maximum flexibility - minimum cost.
I've tried various development boards but didn't like working around the designer's assumptions of what he or she thinks I needed.
I keep several prototype boards ready to go with my currently favorite processors, ICSP header, LED, inverted serial output, and prototyping power supply like this:
http://www.ebay.com/itm/190954315282
Cheers,
Jürgen
www.jgscraft.com
Mike Walne
PostPosted: Mon Jan 26, 2015 4:11 pm     Reply with quote
Cheers,
Just a note. Ebay blocks me from seeing your link.
Mike
ELCouz
PostPosted: Mon Jan 26, 2015 5:07 pm     Reply with quote
Cheers,
Nice product! Thanks purchased two! Very Happy
Regards,
Laurent
ELCouz
PostPosted: Mon Jan 26, 2015 5:08 pm     Reply with quote
Cheers,
Mike
Try the UK eBay link ---> http://www.ebay.co.uk/itm/190954315282
Regards,
Laurent
jgschmidt
PostPosted: Mon Jan 26, 2015 7:29 pm     Reply with quote
And if I have a design I want to keep around a while, I'll transfer the components and jumpers from the proto board to one of these:
http://www.adafruit.com/products/591
and add one of the power supplies. For the hardware and components I can't make my own dual-voltage power supply for that price, especially when I buy them in bulk.
I use these Adafruit boards to preserve the design, and they make a more solid prototype for customer demos before I commit to the circuit design and start making PCBs. I socket the processor and any modules so I can reuse them elsewhere.
Jürgen
www.jgscraft.com
jgschmidt
Back on topic...
PostPosted: Mon Jan 26, 2015 7:43 pm     Reply with quote
Getting back on track, I have several of the CCS development kits. They're pretty reasonably priced, focus on a particular area such as TCP/IP, CAN, USB, etc., and walk you through creating the code for the application. Since they're from CCS, the sample code works with their compilers.
If you're into TCP/IP and web servers, Olimex makes some PIC development boards that I've used. I stick with the simple ones.
http://www.saelig.com is my source. They have a variety of PIC development boards.
Some dev board vendors publish their circuit designs and you can learn a lot from those without ever buying the board.
Cheers,
Jürgen
www.jgscraft.com
PostPosted: Tue Jan 27, 2015 6:03 am     Reply with quote
re: proto work
OK, WHAT do you guys use for boxes to wrap the prototypes in ? I like those adafruit PCBs...do they sell a box for it? Even one for the standard sized board would be nice.
Surely someone sells a 'combo' package perf pcb/ box ? I've looked a few times but can't google the right keywords to find what I want.
Jay
BTW ebay let me see the 'i/o header' fine....
ELCouz
PostPosted: Wed Jan 28, 2015 4:25 pm     Reply with quote
temtronic wrote:
re: proto work
Jay
Most of my systems are open-frame or in a electrical enclosure.
Since with the PIC, there's no big community around DIY boards (like the Pi, arduino,beagleboard and intel edison) no accessories everything is custom made for PIC.
Well we have the generic DIY plastic ugly box.
Wink
Regards,
Laurent
newguy
PostPosted: Wed Jan 28, 2015 8:20 pm     Reply with quote
temtronic wrote:
re: proto work
Jay
I use Front Panel Express (http://www.frontpanelexpress.com/) for both work & personal stuff. They're not cheap but they're exceedingly accurate and high quality.
I've also used Protocase (http://www.protocase.com/). Only used them once but the resulting product was outstanding.
PostPosted: Thu Jan 29, 2015 1:54 am     Reply with quote
I must admit I 3D print quite a few enclosures now. Or CNC cut from layers and bond up.
My casings always tend to be shapes that won't suit off the shelf boxes, for things like probes that need to go into plant. The 'controller' may well use a standard box, but the work is in the little sensor parts.
