ELCouz
jgschmidt
Joined: 03 Dec 2008 Posts: 184 Location: Gresham, OR USA
Posted: Mon Jan 26, 2015 3:57 pm |
I still use mostly solderless prototyping boards and DIP versions of the processor. For larger pin-count or SMD-only chips I get or make my own breakout boards that I can plug into the prototyping boards. That leaves me with maximum flexibility - minimum cost.
I've tried various development boards but didn't like working around the designer's assumptions of what he or she thinks I needed.
I keep several prototype boards ready to go with my currently favorite processors, ICSP header, LED, inverted serial output, and prototyping power supply like this:
http://www.ebay.com/itm/190954315282
Cheers, _________________ Jürgen
www.jgscraft.com |
Mike Walne
Posted: Mon Jan 26, 2015 4:11 pm |
jgschmidt wrote: | I still use mostly solderless prototyping boards and DIP versions of the processor. For larger pin-count or SMD-only chips I get or make my own breakout boards that I can plug into the prototyping boards. That leaves me with maximum flexibility - minimum cost.
Cheers, | Just a note. Ebay blocks me from seeing your link.
Mike |
ELCouz
Posted: Mon Jan 26, 2015 5:07 pm |
Cheers, |
Nice product! Thanks purchased two! _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
ELCouz
Posted: Mon Jan 26, 2015 5:08 pm |
Mike Walne wrote: | jgschmidt wrote: | I still use mostly solderless prototyping boards and DIP versions of the processor. For larger pin-count or SMD-only chips I get or make my own breakout boards that I can plug into the prototyping boards. That leaves me with maximum flexibility - minimum cost.
Mike |
Try the UK eBay link ---> http://www.ebay.co.uk/itm/190954315282 _________________ Regards,
Laurent
jgschmidt
Posted: Mon Jan 26, 2015 7:29 pm |
And if I have a design I want to keep around a while, I'll transfer the components and jumpers from the proto board to one of these:
http://www.adafruit.com/products/591
and add one of the power supplies. For the hardware and components I can't make my own dual-voltage power supply for that price, especially when I buy them in bulk.
I use these Adafruit boards to preserve the design, and they make a more solid prototype for customer demos before I commit to the circuit design and start making PCBs. I socket the processor and any modules so I can reuse them elsewhere. _________________ Jürgen
www.jgscraft.com |
jgschmidt
Back on topic... |
Posted: Mon Jan 26, 2015 7:43 pm |
Getting back on track, I have several of the CCS development kits. They're pretty reasonably priced, focus on a particular area such as TCP/IP, CAN, USB, etc., and walk you through creating the code for the application. Since they're from CCS, the sample code works with their compilers.
If you're into TCP/IP and web servers, Olimex makes some PIC development boards that I've used. I stick with the simple ones.
http://www.saelig.com is my source. They have a variety of PIC development boards.
Some dev board vendors publish their circuit designs and you can learn a lot from those without ever buying the board.
www.jgscraft.com |
Joined: 01 Jul 2010 Posts: 9176 Location: Greensville,Ontario
Posted: Tue Jan 27, 2015 6:03 am |
re: proto work
OK, WHAT do you guys use for boxes to wrap the prototypes in ? I like those adafruit PCBs...do they sell a box for it? Even one for the standard sized board would be nice.
Surely someone sells a 'combo' package perf pcb/ box ? I've looked a few times but can't google the right keywords to find what I want.
Jay
BTW ebay let me see the 'i/o header' fine.... |
ELCouz
Posted: Wed Jan 28, 2015 4:25 pm |
temtronic wrote: | re: proto work
Jay
Most of my systems are open-frame or in a electrical enclosure.
Since with the PIC, there's no big community around DIY boards (like the Pi, arduino,beagleboard and intel edison) no accessories everything is custom made for PIC.
Well we have the generic DIY plastic ugly box.
Laurent
newguy
Posted: Wed Jan 28, 2015 8:20 pm |
Jay
I use Front Panel Express (http://www.frontpanelexpress.com/) for both work & personal stuff. They're not cheap but they're exceedingly accurate and high quality.
I've also used Protocase (http://www.protocase.com/). Only used them once but the resulting product was outstanding. |
Posted: Thu Jan 29, 2015 1:54 am |
I must admit I 3D print quite a few enclosures now. Or CNC cut from layers and bond up.
My casings always tend to be shapes that won't suit off the shelf boxes, for things like probes that need to go into plant. The 'controller' may well use a standard box, but the work is in the little sensor parts. |
