Joined: 14 Aug 2014 Posts: 1 Location: United Kingdom
Using ICD3 with CCS
Posted: Thu Aug 14, 2014 11:04 am
Hello, I wonder if anyone can assist.
I am using an ICD3 MplabX with the CCS IDE/Debugger
I can select the ICD3 from within the CCS IDE and the Debug dialog appears, when it tries to attach the ICD3 a pop up window appears
and ask for "Select JRE Directory". I am thinking this is Java Runtime Environment. But Im not sure what folder to point to, I have tried the Java folder and also created folder but nothing works.
I just get target could not be detected.
Could anyone shed any light on this ?
bkamen
Posted: Thu Aug 14, 2014 9:12 pm
I just use the MPLAB-X IDE with my ICD2/3 and that debugger and use CCS for compile only.
-Ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
