Hello!
I devise a communication with hearing aid via the I2c communication protocol.
Unfortunately, the manufacturer of the so-called hybrid is not stated in the datasheet addresses for communication
Can you share any ideas for accessing an unknown device Using the I2c?
Thank you!
jeremiah
Posted: Fri May 23, 2014 5:56 am
For starters, assuming your hardware is correct, you can scan the bus for addresses
Then see if the address matches any published for a hearing aid hybrid.
Look at the data for the EZAIRO 5910, and the SB3229 as possible ones for a start. The former in particular is often used.
