I2C access to an unknown device
papagal5
PostPosted: Fri May 23, 2014 5:42 am     Reply with quote
Hello!
I devise a communication with hearing aid via the I2c communication protocol.
Unfortunately, the manufacturer of the so-called hybrid is not stated in the datasheet addresses for communication
Can you share any ideas for accessing an unknown device Using the I2c?
Thank you!
jeremiah
PostPosted: Fri May 23, 2014 5:56 am     Reply with quote
For starters, assuming your hardware is correct, you can scan the bus for addresses
http://www.ccsinfo.com/forum/viewtopic.php?t=49713&highlight=i2c+bus+scanner
PostPosted: Fri May 23, 2014 11:47 am     Reply with quote
Then see if the address matches any published for a hearing aid hybrid.
Look at the data for the EZAIRO 5910, and the SB3229 as possible ones for a start. The former in particular is often used.
