eeprom read problem after repowering
dsevgor
PostPosted: Mon Dec 23, 2013 2:23 pm     Reply with quote
I'm having a weird eeprom problem.
I have 2 float variables which i increase or decrease in my main loop, and 2 buttons which they write each variable to their eeprom addresses, and a third button to read both variables and write to lcd.
So far so good. Everything works fine. I increase or decrease both variables save them to eeprom with buttons. Read from eeprom and write both variables to lcd with third button with no problem.
My problem is when i cut the power, repower my circuit and hit the third button before doing anything else (saving new values to eeprom), i get the first value right but the second one returns always 0. But I don't have this problem if i don't cut the power.
Here is my test code. Might be a little long but its not actually.
Thanks in advance
#include <18F2520.h>
#fuses H4
#fuses NOWDT, NOPROTECT, NOBROWNOUT, NOLVP, NOPUT,NOWRT,NODEBUG,NOCPD
#device adc = 10
#use delay(clock=48000000)
#include <internal_eeprom.c>
#include "flex_oled_lcd.c"
#DEFINE JS_RIGHT_PIN                   PIN_B6
#DEFINE JS_LEFT_PIN                    PIN_B7
#DEFINE JS_UP_PIN                      PIN_B5
#DEFINE JS_DOWN_PIN                    PIN_B4
#DEFINE JS_RIGHT                       !input(JS_RIGHT_PIN)
#DEFINE JS_LEFT                        !input(JS_LEFT_PIN)
#DEFINE JS_UP                          !input(JS_UP_PIN)
#DEFINE JS_DOWN                        !input(JS_DOWN_PIN)
#DEFINE EEPROM_ADDRESS_A 0
#DEFINE EEPROM_ADDRESS_B 4
int8 BtnDebounceCount=0;
int8 BtnDebounceCountLimit = 100;
float epromDataA = 0;
float epromDataB = 0;
int1 lcdRefresher = 0;
int8 epromFlag = 0;
#INT_EXT
void readEP(){
   epromFlag = 1;
#INT_EXT1
void writeEPA(){
   epromFlag = 2;
#INT_EXT2
void writeEPB(){
   epromFlag = 3;
void lcdRefresh(){
   lcdRefresher = 0;
         printf(lcd_putc,"\f");
         lcd_gotoxy(1,1);
         printf(lcd_putc,"%.1f",epromDataA);
         lcd_gotoxy(1,2);
         printf(lcd_putc,"%.1f",epromDataB);
   lcd_init();
   port_b_pullups(0x11110111);
   EXT_INT_EDGE ( 0 , H_TO_L);
   EXT_INT_EDGE ( 1 , H_TO_L);
   EXT_INT_EDGE ( 2 , H_TO_L);
   ENABLE_INTERRUPTS ( INT_EXT );
   ENABLE_INTERRUPTS ( INT_EXT1 );
   ENABLE_INTERRUPTS ( INT_EXT2 );
   ENABLE_INTERRUPTS(GLOBAL);
   while(1){
      if(JS_RIGHT){
         BtnDebounceCount++;
         if(BtnDebounceCount > BtnDebounceCountLimit){
            BtnDebounceCount = 0;
            epromDataA +=1;
            lcdRefresher = 1;
      else if(JS_LEFT){
         BtnDebounceCount++;
            epromDataA -=1;
            lcdRefresher = 1;
      else if(JS_UP){
         BtnDebounceCount++;
            epromDataB +=1;
            lcdRefresher = 1;
      else if(JS_DOWN){
         BtnDebounceCount++;
            epromDataB -=1;
            lcdRefresher = 1;
      else {
      if(epromFlag==2){
         epromFlag=0;
         write_float_eeprom(EEPROM_ADDRESS_A,epromDataA);
      else if(epromFlag==3){
         epromFlag=0;
         write_float_eeprom(EEPROM_ADDRESS_B,epromDataB);
      else if(epromFlag==1){
         epromFlag=0;
         lcd_gotoxy(1,1);
         printf(lcd_putc,"%.1f",read_float_eeprom(EEPROM_ADDRESS_A));
         lcd_gotoxy(1,2);
         printf(lcd_putc,"%.1f",read_float_eeprom(EEPROM_ADDRESS_B));
      if(lcdRefresher){
         lcdRefresher=0;
         lcdRefresh();
gpsmikey
PostPosted: Mon Dec 23, 2013 2:47 pm     Reply with quote
One thing I notice that may or may not be a problem but is definitely a potential "gotchya" - the LCD displays typically take a surprisingly long period of time to power up. Running LCD init without a delay of a second or so in front of it can cause the init to fail because the LCD controller has not finished powering up yet (they can be cranky little buggers). Check the spec sheet for the LCD controller for exact timing, but you typically need a delay during startup before doing the init.
mikey
mikey
PostPosted: Mon Dec 23, 2013 2:52 pm     Reply with quote
Another thing is that you may need to clear the interrupts after setting the edge. Generally, there is no guarantee what 'level' is in the edge latches, when the chip wakes up. When you then set which edge is to be used, this can result in the interrupt triggering when the interrupt is enabled.
If you read the Microchip application notes and data sheets, you will find warnings that this can happen....
dsevgor
PostPosted: Wed Dec 25, 2013 6:14 am     Reply with quote
It made no sense when I read your suggestions. This is probably because I'm a "C" noob =)
Nevertheless I've tried what you suggested and it solved my problem.
Thank you so much !! again : )
