I am using the dsPIC33 MC, I want to know if there is a way to use the UARTx pins to print debugging statements to the command window or to the serial monitor which is included in the CCS IDE.
I am new to programming, so any pointers and or example code would help a lot. Thank you!
jeremiah
Posted: Thu Oct 03, 2013 6:08 pm
Yes, but you'll need to get a chip to convert the PIC UART levels to PC RS232 levels. Otherwise it won't work.
