Print to console command window
warren.woolseyiii
PostPosted: Thu Oct 03, 2013 5:08 pm     Reply with quote
Hi all,
I am using the dsPIC33 MC, I want to know if there is a way to use the UARTx pins to print debugging statements to the command window or to the serial monitor which is included in the CCS IDE.
I am new to programming, so any pointers and or example code would help a lot. Thank you!
jeremiah
PostPosted: Thu Oct 03, 2013 6:08 pm     Reply with quote
Yes, but you'll need to get a chip to convert the PIC UART levels to PC RS232 levels. Otherwise it won't work.
Gabriel
PostPosted: Fri Oct 04, 2013 7:49 am     Reply with quote
https://www.sparkfun.com/products/9716
get that, or the 3.3V version... depending on your needs..
or get the MAX232 chip as sugested by others if you do have a RS232 port in your machine.
G.
CCS PCM 5.078 & CCS PCH 5.093
