How can I use driver rtcticks.c
r0n4ld0l1n5
PostPosted: Fri Jul 19, 2013 5:34 am     Reply with quote
Hello, my friends...
I am need help about driver rtcticks.c, please if somebody already used this driver help-me. I've tried and did not work the clock is moving forward.
thanks,
PostPosted: Fri Jul 19, 2013 6:01 am     Reply with quote
What version of the compiler do you have, as I don't have rtcticks.c in my drivers folder?
r0n4ld0l1n5
PostPosted: Fri Jul 19, 2013 6:08 am     Reply with quote
The version of my CCS is 4.140.
PostPosted: Fri Jul 19, 2013 6:29 am     Reply with quote
Yep, rtcticks.c is there, dated August 2012.
PostPosted: Fri Jul 19, 2013 7:52 am     Reply with quote
You have looked at the example that uses it?.
ex_time.c
Uses this if your chip does not have an internal or external rtc peripheral.
r0n4ld0l1n5
PostPosted: Tue Jul 23, 2013 5:05 am     Reply with quote
Yes, I looked... I think this problem is normal, because in all example happened the same thing...
Re: How can I use driver rtcticks.c
PostPosted: Tue Jul 23, 2013 2:13 pm     Reply with quote
I'm sorry, but I don't understand what the problem is. Isn't a clock supposed to count forward?
Did you try the example program ex_time.c and did that solve your problem?
